How can I make some Nismo 370z wheels fit on my g37s sedan?!
Front rim/tire is an easy fit, it's that damn 10.5 +23 in back that needs a lot of help to get a fit. You'd have to run a stretched 255 plus heavy camber (in the -3 degree range) to keep from hitting the fender. You could pull the fender and run better camber and possibly a wider tire. If you can find a full set of just fronts that would be much better for a daily driver. I wouldn't run a staggered Nismo set on a sedan.
i have an 07 g35x. using 1st gen h&r springs. 370z (not nismo) rims, on oversized 245/45 tires. no fender rolling. i only rub a little when i carry people in the back. i'm going to do the droopy butt spacer in the suspension sticky, since i do carry people once in awhile.
i oddly dont have any pictures on my phone. i'll try to remember to upload some later. my rear is slightly tucked, but the front only rubs the liner at full lock
superjoey
31
Mar 22, 2023 11:56 PM
Tunerz_Store
Brakes/Suspension
117
Jul 16, 2018 02:04 PM
