Konig Integram Wheels?
Hi Everyone I'm new to the forum and will be buying a used G37 in the very near future. I found a sale for a G that has winter tires on it and I was thinking rather than just replacing them with summers I would just keep that the tires on the rims and just get new wheels. I was looking to get something mainly for DD but wanted to go to a road track once in a while.
So I wanted to know what you guys thought of the brand Konig and the Konig Integram Wheels? The site says they are made with some flow form technology, is this just marketing or is it actually something to care about? Also do you guys think these are strong enough to track once in a while?
TreadDepot.com: Konig Integram Graphite Wheels
Here's a template to keep handy should the need arise.
Welcome to the site BTW.
Brad
http://www.conceptzperformance.com/i...akeoutline.pdf
Oh, and ask for Andrew over at Treadepot, he gives nice deals when you mention myg37.com
Thanks for the info and the welcome Brad.
I will contact Konig tomorrow to see if the 18" ones will fit or not otherwise try to see if they have 19" ones.
If I were not to be able to get the Konig wheels, is there another brand you guys would recommend for price versus performance and possibly a good place to get them? This is the first time I am buying aftermarket wheels and am not too sure about who is good or bad. Also don't have a great deal of money to spend as I just bought the car, but I don't want wheels that will break.
Thanks again.
Thanks again.
Thanks again.
Thanks again.
Here's the brakes I'm referring to~
A lot of the Konigs have pretty good spacing w/ the spokes from the hub so brake clearance w/ 18s might be a bit easier w/ some of those designs.
The Integrams look to be pretty good in that regard along w/ the Torch, Killigram, Milligram and a couple others, pretty lightweight overall too.
G/L w/ your wheel search, so many options to choose from. Enkeis are another good option in a lighter weight 18s that will clear the BBks.
If you need offset help we can do that, just specify a coupe or sedan, and if it's AWD or RWD.
So I called up the guys at Konig this morning and they said that the 18x8.5 will not clear the brake calipers.
He did say the 19 should fit but will be aggressive. What does he mean exactly, will the wheel rub or scrape the caliper?
So if the 19s have a width of 8.5 or 9 and an offset of +35 or +45 will these wheels fit?
