TPMS Question!
Old Jul 20, 2014 | 06:54 AM
witham9's Avatar
witham9
Question TPMS Question!
2013 G37 sedan currently on stock 17s.
Ordered new wheels and tires(20's)
Arriving separately w/out tpms.
Do you recommend buying new TPMS sensors or can I swap out my sensor in my factory wheels and install them in my new setup?? Will they work even though new tires may require different psi??
Thanks in advance!
Old Jul 20, 2014 | 10:47 AM
AroundTheG37's Avatar
AroundTheG37
Yes you can swap the sensors from your old wheels.
/Thread.
Old Jul 20, 2014 | 11:24 AM
guy from norcal's Avatar
guy from norcal
yeah you can swap them.
Old Jul 20, 2014 | 11:33 AM
MichaelYYZ's Avatar
MichaelYYZ
If you're not going to use the old wheels again, simply swap the sensors. Ensure that you use them in the same location.
I have a 2013 G37S M6 Sedan which came with summer tyres. So I had to buy new wheels and winter tyres that I must swap twice a year. My tyre dealer installed third-party cloneable TPMS sensors on the winter wheels. They work like a charm, I don't need to do any re-pairing when swapping the wheels and the dash light does not come on. The sensors were also cheaper than the OEM version.
The above procedure may be useful if you plan to use both sets of wheels.
Old Jul 20, 2014 | 09:44 PM
witham9's Avatar
witham9
If I remove the "old" sensors and replace em in my new wheels, do you recommend getting new tpms repair/service kit??
Old Jul 21, 2014 | 06:46 AM
pontiacstogo's Avatar
pontiacstogo
Why would you need to do that?
Old Jul 21, 2014 | 06:49 AM
G37Sam's Avatar
G37Sam
New sensors would require to be reset either at the dealer or through a DIY.
Old Jul 21, 2014 | 12:29 PM
GeezerB's Avatar
GeezerB
If this was true, tire rotation would not be possible?
04G35NYC
Dec 24, 2015 01:00 AM
helloandchau
Oct 6, 2015 05:26 PM
Bobo
Oct 1, 2015 10:52 PM
Detailed Image
Lighting/Cleaning Products
Sep 11, 2015 08:33 AM
