Help Would it be ok to buy this size tire?
Old Jul 13, 2014 | 08:51 PM
Buktheng's Avatar
Buktheng
Hi everyone, great forum here. Have a question to ask.
Currently have a 09 G37s Sedan and it has Falken ZE912 tires on them. The front has 225/50/18 and I'm wondering if it's ok to buy 235/55/18 size tires for the front. Don't want to mess up the offset and speedometer. I found a pair for a good price and definitely want to buy it asap before it's gone.
Thanks for the help!
Old Jul 13, 2014 | 10:22 PM
Don't do it, it's going to be 1.32" larger in diameter and 4.68% different than your current size. Use this calculator when trying new tire & wheel setups. For RWD try to be within 3% difference and AWD less than 1%.
Old Jul 14, 2014 | 08:37 AM
witham9's Avatar
witham9
Thumbs up
This^^ 100%!
Old Jul 14, 2014 | 04:23 PM
Buktheng's Avatar
Buktheng
I see, thanks for the help!
Old Jul 14, 2014 | 04:56 PM
Buktheng's Avatar
Buktheng
So for 235/50/18 it says Diameter 0.39" (1.45%)
That would be fine right? Thanks again
Old Jul 14, 2014 | 05:07 PM
blueis300's Avatar
blueis300
The calculator is great but as a quick reference to keep the same diameter go up 10mm in size and down 5mm in profile.
225/50/18
235/45/18
Old Jul 14, 2014 | 10:10 PM
225/50/18
235/45/18
Not that simple, those two tires are off by quite a bit, over 2%.
and if you go another 10mm up and 5 down it's off by 4.4%
If you go up 30mm and down 5 in series you'll be pretty close though.
So a 225/50/18 & 255/45/18 will be close.
Old Jul 14, 2014 | 10:22 PM
blueis300's Avatar
blueis300
Guess I should have used the calculator myself lol. This was something I was told many years ago.
Mattlorentzoe
May 24, 2021 08:49 PM
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
connoisseurr
Sep 20, 2015 04:14 PM
Upser88
Aug 20, 2015 08:30 AM
gcruzjr78
Aug 18, 2015 10:15 AM
