G37 sedan offset fitment question
Jun 27, 2014 | 03:21 PM
'13 G37 Sedan. Looking for offset fitment preferences for both a flush and slightly aggressive setup. Sedan lowered on Eibach Pro Springs.
Looking at 20 inch staggered wheels (20x9 and 20x10.5) wrapped with 245 and 275 tires.
Just don't know what do look for as fas as offsets.
Thanks in advance.
Jun 27, 2014 | 03:39 PM
offset will all depend on how low you are. the lower you are the lower the offset
depending on how agressive you want you should be looking anywhere between +35 to +25
Jun 27, 2014 | 04:54 PM
Here's my setup running 245/35/20 on 8.5x20 +40
295/30/20 on 10x20 +45 Back is flush, front has about 8mm room, but the front fender isn't flat rolled like the rear so I wanted more clearance up there.
I'm lowered to zero gap on coils.
Jun 28, 2014 | 01:27 AM
I was using the wheel/tire calculator on this sight, how many mm of inner clearance does a G37 Sedan, non sport have?
Thanks!
Jun 28, 2014 | 10:12 AM
Jun 28, 2014 | 10:44 PM
Quote:
Originally Posted by
pebkac
Looke great!! What are you lowered on? Did it require a camber kit?
Tire sizes?
Jun 29, 2014 | 12:32 PM
Thank you!
I'm on an Eibach prokit.
20x9 +32 on 255/35/20 and 20x10.5 on 285/30/20
My toe is within spec, and that's all that matter to me right now.
witham9
Tire sizes?
Jun 29, 2014 | 12:44 PM
Pebkac, love those wheels on your G
What's the offset on the rear wheels, 42 or 45 I'm guessing.
Jun 30, 2014 | 08:56 AM
pebkac
Thank you!
Just ordered the same springs myself. Looking for wheel and tire options now.
Thanks for the info.
Tunerz_Store
Brakes/Suspension
117
Jul 16, 2018 02:04 PM
james6980
Oct 9, 2015 01:28 PM
pledes23
Aug 11, 2015 10:54 AM
