Konig wheels
Old Feb 18, 2014 | 12:33 AM
Razorr's Avatar
Razorr
Konig wheels
See Wheels on Your Vehicle - Discount Tire
Will these wheels be able to fit the BBK?
Old Feb 18, 2014 | 01:14 AM
That link you posted isn't specific, what specific rim do you have in mind and its' size?
Old Feb 18, 2014 | 01:40 AM
Razorr's Avatar
Razorr
ohh sorry about that. Here is the link Wheel Details - Discount Tire
Old Feb 18, 2014 | 08:10 AM
rks's Avatar
rks
They should fit. If you run the search using the G with the Brembo option it will filter that wheel as an option.
Old Feb 18, 2014 | 11:36 AM
Razorr's Avatar
Razorr
18X8 5-114.3 45BCB
What does "45BCB" stand for?
Old Feb 18, 2014 | 11:40 AM
sniper27's Avatar
sniper27
It's the offset.
Old Feb 18, 2014 | 01:22 PM
Originally Posted by sniper27
It's the offset.
It means the mounting surface of the wheel is 45mm outside it's centerline, if it's a +45 it means it's 45mm toward the outside of the wheel, if the offset was - it would be offset toward the inside of the wheel. The more positive the offset the more the wheel sinks in to the fender. The stock Infiniti wheels have offsets in the +45 range. If you want to order an 8" wheel that is more flush to fender you'd be looking for something like a +35.
Hope that makes sense.
Old Feb 18, 2014 | 03:02 PM
sniper27's Avatar
sniper27
^^ what he said.
Old Feb 19, 2014 | 04:33 AM
JoshLandry's Avatar
JoshLandry
Witch model has the brembo as I have a g37x and I want to upgrade my brakes to the big brakes and want a wheel that clears thanks
Old Feb 19, 2014 | 08:37 AM
The big brake upgrade is no longer Brembo, it's made by Akebono. Any G37"S"
Coupe 2008+, any RWD G37"S" Sedan 2009+, any G37X"S" Coupe.
Old Feb 19, 2014 | 10:45 AM
JoshLandry's Avatar
JoshLandry
The big brake upgrade is no longer Brembo, it's made by Akebono. Any G37"S" Coupe 2008+, any RWD G37"S" Sedan 2009+, any G37X"S" Coupe.
What about the G37xs sedan does it have the big brakes and if I buy wheels say for a coupe will the offsets ect be diff for the sedan? Cuz I want to upgrade the brakes eventually
Old Feb 19, 2014 | 10:50 AM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
I ain'tcher cousin. As has been said before, the G37Xs only has the aesthetic changes for the sport package. It lacks the big brake kit and larger sway bars that make the normal RWD G37S more "sporty." Be careful when buying staggered wheels meant for a coupe and trying to make them fit onto any AWD car. Switching from the OEM G37XS brakes to the akebono Big Brake Kit is a popular mod.
Old Feb 19, 2014 | 10:56 AM
JoshLandry's Avatar
JoshLandry
I appreciate the help I have a 37x sedan not the S and I really don't want staggered wheels anyway but thanks for the info, so If I buy wheels for a 10 G37xs coupe non staggered they will fit just perfect on my sedan? Yes I'm a noob sorry buddy I'm not new to the car scene just to the G scene thanks again
Old Feb 19, 2014 | 11:04 AM
GoFightNguyen
Because Racecar
No worries. They will fit as far as rolling diameter goes, and I *suspect* that they will fit fine for offsets also. Brad is the guy to ask about that. The issue with AWD G37's is that the AWD system gets very unhappy if your rolling diameters differ more than 3%.
The problem you MIGHT run in to is that the G37XS coupe does NOT come with the big brake kit, thus the OEM wheels have no need to clear the big brake kit. If you put X coupe wheels on your X sedan, they might fit fine with your regular brakes, but you might run in to troubles when you decide to upgrade to the big brake kit. Get me?
Old Feb 19, 2014 | 02:20 PM
Josh shoot me a PM w/ exactly what you're wanting to do and hopefully I can give you some ideas
Brad
helloandchau
Oct 6, 2015 05:26 PM
Amrit.bhathal
Sep 11, 2015 07:36 PM
xpcgamer
Sep 7, 2015 07:10 PM
Sylo
Sep 3, 2015 04:44 PM
