18 inch wheels on S coupe for winter
Sorry to ask such a dumb question but Im looking at swapping out of the Max into a G37S coupe. I just bought a set of 06 M35x 18in wheels and put some Dunlop Wintersport tries on them. I will be keeping this set and was curious if I could slap these on the G37s. They are 18x8.5 but I cant track down the offset.
If they dont fit I need to track down Spacers to make them fit.
G35/G37 OEM wheel specifications & after-market wheel offsets : G35 and G37 Suspension, Brakes, Wheels and Tires
The coupes come w/ pretty conservative offsets from the factory so the Max wheels shouldn't be too far off. Here's the OEM wheel specs for Infiniti Gs
http://www.conceptzperformance.com/i...akeoutline.pdf
http://www.conceptzperformance.com/i...artemplate.pdf
If you have the wheels on hand you can always use these templates (glued to some cardboard) to check for clearance rather than doing a blind fit and possibly scratching up your calipers. If nothing else it'll tell you how much spacer you'll need to clear them.
I will see how it goes and let everyone know.
