20'' wheels on g37x coupe
There is a guy who is selling "All Front 19x8.5 coupe wheels and tires".
He says that they are general g max tires all 225/45/19.
Do you think these size will fit perfect on my AWD coupe with Eibech spring?
I am just worried about AWD system so I keep asking you.
Again, thank you for your time and consideration!!
Is it possible to put thin tires on OEM sport wheels?
The ones that I am trying to buy have think tires. Do you know what I mean?
What I mean by thin tires is....
https://www.google.com/search?q=voss...l%3B1024%3B764
If you mean low profile (thin sidewall height), yes you can do it, you just need to have your diameter almost the same as your stock diameter. as your wheels get larger in diameter your sidewalls must get smaller to keep the diameter the same. Hope that makes sense
I run 20"x8.5" Fronts and 20"x10" rears on my 2009 G37X coupe. No issues so far with over 30k miles with this setup. Tire size for fronts is 245/35/20 and rears are 285/30/20. My car is lowered on Eibach springs. I think the wheel size looks perfect.
Spicy_Kimchee
Aug 11, 2015 09:10 AM
