235/60/18 on fronts work?
Old Dec 2, 2013 | 03:30 PM
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
just a quick question...will 235/60/18 fit the fronts of my S? I know stock is 225/50....
Old Dec 2, 2013 | 03:58 PM
blazeplacid's Avatar
blazeplacid
should be fine
are you dropped?
Old Dec 2, 2013 | 04:08 PM
canucklehead's Avatar
canucklehead
^ uhh, no. the OD on the 235/60 will be 8.4% larger than stock 225/50. that is way over the recommended variance of +/- 3%. at 60mph your speedo would be off by more than 5mph. plus, it would look like a truck tire.
OP - i suggest you use the tire size calculator tool in the TECH section.
Old Dec 2, 2013 | 08:42 PM
WHS^^^ please use this tool for finding proper tire replacements
If you want a 235 or 245 width you need 235/45/18 or 245/45/18.
Old Dec 2, 2013 | 11:26 PM
dkmura's Avatar
dkmura
20 Year Member
Using a tire with such a large sidewall will also cause your G to handle strangely. Braking will be thrown off and you'll cause some ABS problems too. Don't do this!
Old Dec 3, 2013 | 09:02 AM
Daddy Fat Sacs
ok seems like the consensus is a no, was just asking as I ran across a good deal on some Goodyear Eagle F1's, but I'll just stick to the oem 225/50, thanks all for your input
GW330
Feb 2, 2024 05:41 PM
Lt8Che
91
Apr 8, 2022 04:55 PM
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
warpeacelove
Oct 28, 2015 02:59 AM
