First Post :) G37X coupe tire help
Hi Everyone,
I just joined the Infiniti family from BMW and need to purchase winter tires.
4x Michelin X-Ice 3 ,
Now Configuration :
Stock : 225/50/r18
I'd like : 245/50/r18 REAR
225/50/r18 FRONT
OR
245/50/r18 All Around Front + Rear
245/45/r18 All Around Front + Rear
Would really appreciate some advice
Thanks in advance
LOVE THE G37X COUPE 2009
Now Configuration :
Stock : 225/50/r18
225/50/r18 FRONT
OR
Thanks in advance
Keep the same size all around for the AWD models otherwise your going to hate yourself later.
The 245/50/r18 will be a very very slight more soft ride. Otherwise it will be identical.
Oh and good choice with the x-ice! I love those tires, you can do anything with them!
If you want to keep the rolling diameter as close to stock as possible with 245s you'll want 245/45-R18 all around -- those tires will be within 0.66% of stock diameter. 245/50-R18s are 2.85% larger than stock, and I've read that a 3% or more delta from stock can cause the AWD system to throw codes. You can compare different tire sizes using the forum's Tire Rim Calculator.
Yep, those 245/45s will be great. I've read a few AWD guys having problems w/ diameter differences over 1% when they reach speeds over 80mph their VDC dash lights have been activated. It seems that the common 3% +/- diameter difference would be better to apply to RWDs and the +/- 1% for the AWD models.
BTW, welcome to the site!
If you have 18s you'd want 245/45/18, if you have 19s then it would be 245/40/19
drewfinity
Aug 20, 2015 08:17 PM
