fitting 20x11" +15
Old Jul 4, 2013 | 05:09 PM
Italia311's Avatar
Italia311
Question fitting 20x11" +15
Hey guys, I plan on selling my current wheels and going for the K3 Projekt projekt one's w the 5" rear lip, 11" wide+15. I came across a couple old thread on here with people asking for fitment help but with no real one direction answer or any end result. I emailed a sales rep and they said that I will need to pull rear fenders and use spacers to clear BBK, and i also plan on running 255wide falkens because i hear they stretch well. I know its doable because i've seen much more aggressive wheels run before. Im slammed currently on BC coils, so height/drop adjustment isnt an issue, and I also have spc rear camber kit installed. Any/all help is much appreciated as Id like to order these ASAP, thanks!
Old Jul 4, 2013 | 07:20 PM
BLAIR'N G372012's Avatar
BLAIR'N G372012
Ive seen fender pulls on the rears... creases and damage to the Fenders yet the wear bumper for being such a - camber to run them... v12's stretch nicely as well yet I run them on my setup...look into the Aggressive fat tire threds their are some there that can help you .... doggy did his but his was a body welded pull... if its not done right it will look horrible .... yet running such camber you'll run through tires too...
Good luck
Old Jul 4, 2013 | 07:21 PM
BLAIR'N G372012
Contact VA55 he had DPE set up too... send him a pm he'll help you... Vons a great guy!
Old Jul 4, 2013 | 10:00 PM
BeefMaster's Avatar
BeefMaster
11 +15 is totally doable on a coupe. I had the exact measurement stretched on a 265. Pretty slammed too. Only had to run -3.5 camber. But if you have to add spacers, that might be a problem
Old Jul 5, 2013 | 08:40 AM
Italia311's Avatar
Italia311
Thanks for info guys. My car isn't a DD so camber isn't a huge issue, it's just the fender roll I'm worried about because I've seen some that looked like Blind man went at their fenders.. W the spacer the end offset will prob be +5. What tire size would be suitable, 255 or 265?
Old Jul 5, 2013 | 08:46 AM
Italia311's Avatar
Italia311
Also, I'm pretty slammed now running -4.5 camber, if I were to raise it a bit and camber accordingly, can I avoid the fender pull?
Old Jul 5, 2013 | 12:00 PM
fairladyz34's Avatar
fairladyz34
The rears won't clear the bbk? Or did the rep mean the fronts won't clear, the front is usually the issue. The 11+15 will work, camber stretch and coils should do it and it see like you already have all that covered. Just trim the bumper bracket and shave the fender well carpeting, should be good. My most aggressive rears were 10.5+0 and they didn't need a pull
Old Jul 5, 2013 | 12:48 PM
Italia311's Avatar
Italia311
A vendor on here told me
Only fronts need spacers, and a rep from the company told me rears too but didn't even know what size lol. Va_55 told me he had to pull his fenders and run -8 camber.. Waiting to hear back if it was the same setup or more aggressive, because if so then these wheels can pound sand lol. But if I can get away with no spacers and camber around -4 then I'm goin for it
Old Jul 5, 2013 | 04:26 PM
TheGanglyGoon's Avatar
TheGanglyGoon
You can't fit those specs without ruining your fender or crazy camber
Old Jul 5, 2013 | 05:29 PM
Italia311's Avatar
Italia311
I'm not gonna **** my fender up, but I don't mind running -5 camber (just throwing a number out there) if need be, as my G isn't my daily.
Old Jul 5, 2013 | 09:25 PM
Yang88she's Avatar
Yang88she
You can if you roll your fenders, I run 10.5 +15 with only -3 camber, no rub n I'm 1/2 inch above the rim
Old Jul 5, 2013 | 11:10 PM
Italia311's Avatar
Italia311
Sweet. I might go for these. Thanks for all the help so far fellas. Keep the info comin tho!
Old Jul 6, 2013 | 01:40 AM
TheGanglyGoon
i run a 10.5 +10 and in theory the rims you are looking at are a 10.5 +9... I run -5.5 camber so hopefully you can get close with that. -6 maybe...
Old Jul 6, 2013 | 03:28 PM
Italia311's Avatar
Italia311
awesome. if i were to raise the coils a little bit, you think id get away with -5/-4? planning on stretching 255/30/20's
Old Jul 7, 2013 | 09:47 AM
Italia311's Avatar
Italia311
did you roll or pull your fenders? to my understanding, theres little ( to none) to roll on the coupes
