Help TPMS Warning Light
Old Jun 28, 2013 | 08:04 PM
stvsfx's Avatar
stvsfx
TPMS Warning Light
Hey all,
So after I did the 2010+ nav swap my TPMS light blinks and stays solid on startup. I was finally able to pull the code using the Sticky Modme wrote. The code pulled was 52 (Vehicle speed signal error). To me this makes no sense, since I wired everything correctly. I know it's hooked up correctly because certain features of the nav unit don't operate when the car is moving (i.e. speed signal detected). I know most people haven't attempted this mod, but has anyone ever gotten the code above? What could I do to clear this code, that part in Modme's write up didn't work.
Modme's write-up here
Thanks for any help!
Old Jun 28, 2013 | 09:27 PM
BLAIR'N G372012's Avatar
BLAIR'N G372012
Im not sure though someone will chime in... one of the years they Switched the TPMS Meaning that like 08-10 were one set and the 11-13 were a different set of TPMS sending off different codes ... again I seen this somewhere ... like the G35 Tpms are yet wont work with ours on certain years... if you did a Screen Change thats set up on recognizing those type...
Good luck
04G35NYC
Dec 24, 2015 01:00 AM
Bobo
Oct 1, 2015 10:52 PM
JG_G37
Sep 19, 2015 09:07 PM
B Feelgood
Sep 13, 2015 05:56 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
