Help coilover damper extensions
has anyone installed a pair of coilover damper extensions? I was thinking about doing it for my Stance SS but not sure how involving it is. I googled a good amount on it and can't really find anyone that has a write up on it. Also if anyone has a set of installed pictures that would help a lot with learning where they would be placed. Thanks!
If this is what you're referring to, then here you go.
BC Racing Strut Extender Extenders
Basically, just find some used speedometer cables of similar thickness (or more, since you are extending it and want it to stay stiff.)
FWIW, i did manage to get back to the original length extenders from BC and got it where it just barely snuck out of the top of the rear seats.
Basically, just find some used speedometer cables of similar thickness (or more, since you are extending it and want it to stay stiff.)FWIW, i did manage to get back to the original length extenders from BC and got it where it just barely snuck out of the top of the rear seats.
4DRZ
Engine, Intake and Exhaust
12
May 18, 2017 11:25 AM
