245/40/19 all around fit
Would 245/40/19 all around work on a '08 Sport?
Numerically speaking, it looks as if it would work with the stock 19" rims, but confirmation is always nice. I'm using the info below (taken from BB's post a few years ago)
Front:
Wheels: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Rear:
Wheels: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Front:
Rear:
Yes those tires fit on both the front and back wheels. The front tire size is not made to fit on a 9" wide wheel like the back wheels though. I am thinking about running those all around when I have to replace mine so they can be rotated front to back.
Front:
Rear:
Front:
Rear:
^^ MM you should chime in on this thread: https://www.myg37.com/forums/g37-cou...ould-i-do.html and let the OP know you are rolling that configuration. He had his wheels stolen off his AWD, acquired a set of staggered wheels like ours and isn't sure what to do about it.
37
10-17-2020 11:12 AM
