Camber needed to fit 370z rear wheels on Sedan
Old Apr 4, 2014 | 09:39 AM
hinomura's Avatar
hinomura
Hey guys, I tried searching every thread available in the forum on this issue. Please forgive me if my detective work isn't up to par. People would reply yes or no as to whether the setup would work but I never found a thread with hard numbers. My current setup is a G37S sedan lowered on Eibach springs. I have front and rear camber kits w/ toe bolts. The rear tires on the Rays Forged Mantis Rims are 275/35/19. Exactly how much camber would I have to run to get it to be tucked enough so it doesn't rub? More than -2.0? Also, at which camber value does extreme tire degradation begin? More than -2.0? More than -2.5? Any help would be greatly appreciated. Thanks.
Old Apr 5, 2014 | 09:37 PM
This thread should help, Loki (the one w/ the Red sedan) is dropped on Eibachs and seems to be OK w/ the fit. camber is probably around -1.8 to -2 as this is what most Eibachs drop to w/out camber help.
https://www.myg37.com/forums/g37-sed...for-sedan.html
Old Apr 20, 2014 | 04:33 PM
conkus805's Avatar
conkus805
Just FYI, I pm'd loki about this exact question and he stated that he is running no rear camber adjustment. He is just dropped on eibachs. Hope this helps.
Edit: I guess he has spc rear arms, so he is running some sort of camber adjustment.
james6980
Oct 9, 2015 01:28 PM
Redfire32
Aug 11, 2015 09:05 AM
ddayeg37s
Aug 9, 2015 07:10 PM
SS2006
Aug 9, 2015 05:32 PM
