offset help
offset help
I have a 09 x (AWD) and I was wondering for 20 inch rims, what should the offset be so i can use my G as a daily driver without rubbing? If I was running staggered and if I wasnt what should the offset be?
What about for 19s and 18s?
Heading to a thinner tire is rough especially for a DD commute...
Pv remember Lowered vs Stock height plays a factor as well on sizes and offsets...
Sent you a PM Himalaya... Coupes can do a whole lot more than Sedans...its about what you want the car to look like ...thats what its all about...
I run a 245/35R20 +32 in the front and 285/30R20 +40 in the rear. Fronts are pretty damn close to flush, rears you could easily pull a +35, but I'm planning to bring the camber slightly more positive to like a -1.1 which should bring it about flush.
Edit - I'm dropped on the Eibach PK springs at the moment.
Sorry guys for digging up this thread, looking for new wheels. I want to be sure I get the ones I want before i get something and regret it
I'm not getting coils as of now and im sure of that, ill be getting eibachs. I'm also looking into the H&R lowering springs for the AWD now since its just a tad bit lower
With the AWD g37, I have to stay within 5 for the awd to continue working is that correct? So with the H&R or even eibach, Which would sit more flush?
Option 1: Front: 245/35R20 +32
Rear: 285/30R20 +45
Option 2: Front: 245/30R20
Rear: 275/35R20
Rear: 285/30R20 +45
Rear: 275/35R20
Option 1 will keep the rolling diameters closer. The rears I would recommend at least a +40 (that's what I've got) and might even say go for a +35. On Eibachs the 32/40 combo kept the tires pretty flush with no rubbing.
ck1109
Oct 15, 2015 11:06 PM
Kojack
Oct 9, 2015 05:53 PM
