question on rims
Old Dec 4, 2012 | 02:01 PM
Originally Posted by NerminG37
thanks alot for the information ! your car looks really good i like it..ive been looking for that spoiler that you have where did yu get i and did you have to take off the old little chrome spoiler?
No problem
The spoiler is the oem lip spoiler, and yes the chrome is removed. If you decide to get one let me know, there's a thread that'll show you the install without having to drill the outside two holes (so you can go back to stock if you want or are afraid to drill your car ) Most Infiniti dealers & part sources sell them. Discountinfinitiparts would be one.
Originally Posted by MACS
Dang, bro... I really need to get my chrome blacked out. That looks sweet.
Thanks for the kind words MACS, just follow my easy DIY and save some $$
https://www.myg37.com/forums/d-i-y-i...-g-sedans.html
Old Dec 4, 2012 | 04:03 PM
pg37's Avatar
pg37
Originally Posted by My'09G37X
They're the gun metal M37S/56S rims.
http://www.ridelust.com/wp-content/u...2/11/Main1.jpg
Any idea the weight on those?
Old Dec 4, 2012 | 05:08 PM
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
I'm not really sure. I'll try to look it up a little bit later and find out.
**Edit: I couldn't really find the "official" weight listed anywhere but from what I was able to find by searching some forums they're between 20 and 25lbs. But don't hold me to it if it's wrong.
Old Dec 5, 2012 | 02:14 PM
pg37's Avatar
pg37
Im going to hold you to that.
Old Jan 19, 2013 | 06:26 PM
NerminG37's Avatar
NerminG37
Keep in mind you need to keep the outside diameter of your tires within 3% of the oem tire diameter to keep your traction control and speedometer/odometer within a reasonable range. The 18s will have a taller sidewall, the 20s a narrower sidewall to accomplish this.
Here's three pics of my G w/ 20s~ first pic is a long time ago showroom stock (w/17s), next is 20s before lowering, the last pic is lowered w/ no fender gap (and same wheels but blacked out). Even a mild drop to reduce the fender gap really improves the look, so no need to go as low as this if you don't want to
HTHs
hey i wanted to know, where did you order your spoiler and how does the old one come off ?
Old Jan 19, 2013 | 07:50 PM
rpm&my_G35's Avatar
rpm&my_G35
^ blnewt has the OEM rear trunk spoiler and front chin spoiler. Get them from the dealerships.
The DIY section has lots of help for you.
https://www.myg37.com/forums/d-i-y-i...r-install.html
Old Jan 19, 2013 | 09:21 PM
Boywdr's Avatar
Boywdr
Good point^^
I have 20s and am getting new 20s this week but there are definitely some significant tradeoffs for the look. The low profile sidewalls do hold up well for cornering but you will get a harsh ride by comparison for the smaller amount of rubber between the car & the road. The weight of the bigger wheels & tires will be noticeable, not too much if you keep the weight fairly close but still something to consider as most cast 20" rims can be 20% heavier or more compared to oem 18" wheels. MACS has some wheels that are 20% lighter than oems so he's really feeling a nice improvement.
I don't mind sacrificing a bit of pep & mpg for the look of a nice 20 but you do have to be more careful too as a big pothole can slam a 20 but only a minor annoyance on 18s.
19s are a good compromise but the tires cost a fair amount more than 20s
you are so right now that i think about it.... i am going to now be more open to some 19 or some really i mean really good looking 18's being that my car came with the 18'' sport wheels how wide can i go if i got 19 or 20?? 20x10 or 19x10 will rub if i got all around cause of the AWD?
Old Jan 19, 2013 | 10:07 PM
rpm&my_G35's Avatar
rpm&my_G35
^ Much would depend on the wheel offset.
Someone else here was recently asking if he could put 10" all around. I think the final answer was yes. Edit - with some extra negative camber on the fronts
OneSickBlackG
Jan 6, 2016 08:49 AM
Clutch34
Sep 14, 2015 03:26 PM
Detailed Image
Lighting/Cleaning Products
Sep 8, 2015 02:39 PM
pauliewalnutzz
Sep 8, 2015 11:41 AM
allen738
Sep 6, 2015 09:36 PM
