Help Tire Suggestions
Old Jun 5, 2012 | 03:07 AM
ReddieG37's Avatar
ReddieG37
Tire Suggestions
I will be lowered on Tanabe coilovers with the following wheel specs.
20x9.5 +22
20x10.5 +25
I was looking at these two tire options. Which set would fit better for the wheel specs above? Or any other recommendations on different sizes?
Option 1
225/35/20
255/30/20
Option 2
245/35/20
255/35/20
Old Jun 5, 2012 | 12:02 PM
Option 3
245/35/20
275/30/20
Old Jun 5, 2012 | 12:08 PM
BosMaSwaG37's Avatar
BosMaSwaG37
245/30-20
275/30-20
Old Jun 5, 2012 | 12:36 PM
ReddieG37's Avatar
ReddieG37
Option 3
245/35/20
275/30/20
The fronts will fit, but what I'm worried about is the rear. I believe a member here had 10.5 +27 with 275/30/20, and it required a lot of fine tuning and stiffening up the rear to make it work. Plus I believe the Tanabe coils are too soft for this setup? My rear fender liners and bumper brackets are shaved.
Old Jun 5, 2012 | 01:18 PM
That depends on how low your car is. There's always the seemingly unpopular or unknown option of raising your rear height just a few mm until it clears the tires so you can fit tires/wheels that have close the same circumference as OEM. This is my suggestion. Otherwise you will have to stretch the tire or make other accommodation.
Old Jun 5, 2012 | 01:20 PM
Fentress24's Avatar
Fentress24
Those rears should be fine. I am on 275/30/20 on a similar set-up. Completely shaved the rear fender bracket and trim the liner and you will be fine. I am also on Tanabe Coils. It required a little work but now it sits perfect.
It all really depends on how low you plan on running the car.
Old Jun 5, 2012 | 01:28 PM
Yes.
Whether or not a tire/wheel combination will fit is dependent on the height you're set at. I'm on Tanabe coils as well and had 285/30/20 in the rear until I recently changed to 275/30/20. I had no problems with the wider tire, I went with the narrower one because the 285 wasn't in stock in the tire I have at the time. I have shaved bracket and trimmed fender liner as well but I'm probably a few mm higher than many others on the same coil so my wheel/tire fit without an issue. For me it was easier to raise the car a turn or two than to change the size of wheels and tires to make them fit.
Old Jun 7, 2012 | 06:25 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
245/35-20
275/30-20
or
245/35-20
255/35-20
ZachThomas
Sep 3, 2015 01:40 PM
