Lowered G37S - horrible tire wear
Old Mar 30, 2012 | 06:11 PM
Originally Posted by k.diaz1105
I'm dropping my car on Eibach PK this weekend. I just want to make sure I'm not going to have to much of a tire wear issue? Should I think about getting a camber kit?
It's a close call. I'm dropped deeper than Eibachs and DIY'd the install so I just did everything at once since I knew w/ the aggressive drop I'd need the F&R kits. It's easier to install the arms, toe bolts and springs at the same time so that may be something to consider. Lots of guys dropped on Eibachs get by w/ the stock arms possibly running camber a bit out of spec. You can install the toe bolts pretty easily (if you have a dremel tool). If you want to just get the springs and get it aligned, then if they can't get the toe in spec just buy the toe bolt kit (it's about 50 bucks). You probably won't need the camber arms if you don't mind running a bit excess camber (if they can't get it in spec).
Old Apr 1, 2012 | 04:25 PM
botlfed98's Avatar
botlfed98
pics of drop/stance?
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
i heart ricers
12
Dec 9, 2015 04:15 AM
sLADe781
32
Nov 28, 2015 03:23 AM
Broski28
Photoshop
Aug 9, 2015 10:19 AM
TakmaN
Aug 8, 2015 07:47 PM
