TE37 Tokyo Time Attack (TT)
Old Mar 7, 2012 | 03:10 PM
  #136
jsp872's Avatar
jsp872
Originally Posted by WPPJR30
The Tokyo Time Attack does not come in a 10" (+22), only 10.5". To answer your question about stretch, no, you will not have to run a stretched tire. I am currently running a 19x10.5" (+22) rear wheel on a 275/35/19 tire and my car is lower than an Eibach PK drop. For what it's worth, though, I could not have fit a 285/35/19 back there.
first i would like to apologize to German for thread jacking...
I saw the SL's on your ride, and huwee's, (i think)
I'm trying to decided between the two right now,
I'm going to start tracking my car in a few months,
Do you think running 10.5 +22 on the rear is okay for the track & driving very aggresive?
or would you recommend otherwise?
I feel like your car sits higher in the back, from the pictures.. or is this an illusion? lol
Thanks for all your help.
Old Mar 7, 2012 | 03:28 PM
  #137
WPPJR30's Avatar
WPPJR30
I think 10.5" (+22) with an Eibach PK drop will be fine on the track. Huwee and I, although wearing the same shoes, have two very different set-ups. He is stretching 255/35's in the rear and is pretty slammed. My set-up is less aggressive. Also, keep in mind that a little bit of negative camber is a good thing.
I have actually installed Eibach springs on my car and my current drop on coilovers is lower, although far from slammed.
It's difficult to say when I am not exactly sure what you are going for with your build, but, to me, the +22 rear offset is a just a bit too aggressive for a G. That's me, though. I have always been a proponent of function over form. My new wheels should be installed shortly and the offsets are a little more conservative. Not much, but I think it will be just enough to please me. I am looking forward.
Old Mar 7, 2012 | 03:33 PM
  #138
jsp872's Avatar
jsp872
I agree with you, I am a fuction over form person too, although look is important too lol
Is there any way to achieve the 19" X 10 +35 look that German has on his TT on the SL?
I really like how German's rear sits. It looks perfect to me.
But then again... I want that concaveness on the SL
this is a hard decision....
Old Mar 7, 2012 | 03:38 PM
  #139
WPPJR30's Avatar
WPPJR30
That's the thing... German wanted to run a 285 rear tire, so he picked the conservative offset. If he had chosen the +22 rear offset, he would have the same concavity of the SL, but he wouldn't be able to run a 285 rear tire. It's a trade-off.
Old Mar 7, 2012 | 05:16 PM
  #140
frty9rsfn's Avatar
frty9rsfn
+22 only comes in 10.5 like Bill said... like the look myself but it sticks out to much for performance in mind...
285/35 def wont fit...
As i was making my decision, i was looking at Lou's 10.5 + 22 on his rears w a 275/35 and complete shaved bumper bracket and still rubbing... not very attractive for what i had in mind...
Old Mar 7, 2012 | 05:24 PM
  #141
frty9rsfn's Avatar
frty9rsfn
Would I have to run stretched tires, on 19"x10" +22 Tokyo Time Attacks ??? dropped on eibach pros
I love the flushness of German's rear wheel & tire combo.
I will be going for a performance minded set-up, like German did, but would love that concaved rear wheel.
+22 is too aggressive... specially if your thinking of performance in mind... like i showed on the pics... at 10 + 35, i was still rubbing... im as flush as i can be without having to run more negative camber... its perfect...
with my set up, a + 30 instead would be as flush as the front but i would def be rubbing turning into driveways and would have to shave complete bracket... some people mind a complete bracket shave...
i had to trim all the way to the bolt and didnt mind that but was hating that i was rubbing... it bothered me and i wasnt happy... however, it was an easy fix...
i have the opportunity to do a 5mm spacer to make it sit exactly as front... however, if you go even just a bit to aggressive, you cant go backworths... keep that in mind...
Old Mar 7, 2012 | 05:28 PM
  #142
frty9rsfn's Avatar
frty9rsfn
haha.. no worries... Bill is the man...
Old Mar 7, 2012 | 05:34 PM
  #143
redrover23's Avatar
redrover23
They make a 10.5 +32, TE37 TTA that is.
Old Mar 7, 2012 | 05:37 PM
  #144
frty9rsfn's Avatar
frty9rsfn
the SL only offers these offsets
too conservative - 19x8.5 + 52
too thin and conservative for rear - 19x9.5 + 22
too aggressive for rear - 19x10.5 + 12 and + 22
no 19x10 + 35...
took me a year to figure it out too, dont rush this porcess...
thats why i started this thread as a refence for a performance oriented set up with 285's...
  #145
jsp872's Avatar
jsp872
Would you go 9.5 +34 instead of your +22 right now if you could change it?
or do you think you like it as is?
I saw the pictures you posted but thought your front was just a tad agressive,
Old Mar 7, 2012 | 05:42 PM
  #146
frty9rsfn's Avatar
frty9rsfn
yup and wheel will extend an extra 9 mm more...
Old Mar 7, 2012 | 05:45 PM
  #147
jsp872's Avatar
jsp872
I'm just going to post this for a quick reference purpose lol
It's the offsets offered for the TT, and the SL
TE37 TT
TE37 SL
Old Mar 7, 2012 | 05:50 PM
  #148
frty9rsfn's Avatar
frty9rsfn
i see what youre saying and it would extend half and inch less with a +34... but i really like how it sits right now... i dont think you would be dissapointed with a + 34 though...
the front sits as i wanted it too... like i said, i was looking at a set up with a +22 up front and a + 22 in rears... front, to me, looks as aggressive as i wanted to be, but rears were to aggressive...
+ 34 in the front to a + 22 is a 12mm difference... 0.47 in. diff...
same front shot as ealier in the thread... for reference (love the way the front sits also)
Old Mar 7, 2012 | 05:51 PM
  #149
redrover23's Avatar
redrover23
yea, proly can't pull a 285 off without mad camber...or at least out-of-spec camber.
I'm curious what camber is required for a 10.5 +32 with 275 tho.
These wheel threads usually channel into a wheel fitment discussion LOL.
Old Mar 7, 2012 | 06:32 PM
  #150
WPPJR30's Avatar
WPPJR30
Ride height and camber are contributing factors, as well. Lou and I are running the exact same set-up in the rear and I do not rub. Lou's G sits a bit lower than mine, though. I'm not sure what his camber specs are, either.
Thanks, bud...
I think Lou would agree with me that 9.5" (+22) is almost the perfect offset for the front of a G coupe. Again, opinions differ, but it is aggressive, but not too aggressive. I run a 255/40 on my 9.5" (+22) front currently. If I were to do it again, I might go 245/40/19.
I don't know for certain, Aaron, but I would suspect that it would sit rather nicely. Like I said, I think (+22) on a 10.5" wheel in the rear is just a bit too aggressive for a G. Again, my opinion.
