Best tire size and offset for 20x10 and 20x11?
Tire and fitment question
Hi i have a g37 journey and im planning on getting some varrstoen rims that are 20x10 and 20x11. ALso on planning on getting Tein Superstreet coilover to. Does anybody know what offset would work? Do I have to worry about clearing brakes since its not a sports model? Camber issues? What tire sizes would work for those rims?
if you want to run those sizes then you will need higher than normal offsets.
if you are doing 20x10 front a +40 would work fine, and 20x11 rear a +40 also.
these sizes would give you more clearance than lower offsets. for tires you can run a 255/30/20 and 285/25/20 rear. I also think the natural camber from lowering your car would be enough because in order to fit these sizes you would have to drop the car significantly. I suggest you do some more research on the sizes because its tricky working offsets on sizes that have not been used a whole lot.
Are you getting the new 1.1.3. coming out in April?
I live in Canada. You know if there's a site I can get Varrstoens at?
I was planning to get the same setup. I think it would fit with a decent amount of camber, camber kits if you don't have already, and getting rid of that rear bumper bracket.
