AWD coupe offset
Old Jan 23, 2012 | 10:55 AM
vmfldis's Avatar
vmfldis
AWD coupe offset
Hi,
I'm thinking of getting Vossen CV3 20/9/20 all around with 245/30/20 tires. Can anyone tell me if this setup will be too aggressive for my AWD coupe?
Thank you.
Old Jan 23, 2012 | 06:26 PM
OB G's Avatar
OB G
Are you saying you intend on running 20x9 +20 all around?
Are you dropped or on stock height? If dropped, you could make it work. Fronts will be aggressive but rears will be conservative unless you get some spacers I think. If you aren't you'll have 4x4 status and look like an SUV.
Old Jan 24, 2012 | 09:27 AM
vmfldis's Avatar
vmfldis
Ya, 20x9 +20, if offset doesn't affect AWD system i'm thinking of running 20x9+32 on front and 20x9+20 on rear. I'm also going to drop the car with Eibach kit. Does this sounds better?
Old Jan 24, 2012 | 02:15 PM
Sunny G's Avatar
Sunny G
If you drop your car on eibachs you can run 20x9 +20 with a 225/35/20 front and 20x10.5 + 32 with 265/30/20 tires on the AWD without any issues at all. If you want a wider tire you can run 245/35/20 and 285/30/20 with a +32 front offset and +45 rear offset
Old Jan 24, 2012 | 06:02 PM
OB G's Avatar
OB G
OP just run the staggered wheels. Idk why you want to get it all the same width. Is it b/c you want to rotate your tires? If so, you won't be able to anyways with those offsets. If you're still worried about the AWD, you can rest assure knowing that I'm running 20x9 +32 / 20+10.5 +42 with 245.35/285.30 tires on my X with no issues.
G37xhibeet
Nov 15, 2016 09:29 AM
Dillybar12
Aug 17, 2015 04:52 PM
jakebeefsteak
Aug 14, 2015 10:23 AM
350zrunnin12s
Aug 9, 2015 09:55 PM
Abramite
16
Aug 8, 2015 08:35 AM
