Will OEM 18's fit S coupe?
Old Nov 23, 2011 | 03:19 PM
myk1013's Avatar
myk1013
Hi, just wondering... has anyone tried on the oem 18" wheels (split 5 spoke) on their S coupes? I'm talking about clearing the Akebono brakes with spacers.
Thanks.
Old Nov 24, 2011 | 07:22 AM
emyrl's Avatar
emyrl
I haven't tried this myself, but I HEARD they wont clear. I'd try it if I had the time...I've always wondered about this myself.
Old Nov 24, 2011 | 03:39 PM
NCHIINFMNGR's Avatar
NCHIINFMNGR
one of my cust did it and it clears while in car is in the air but when turning the rims scuff the outside of the caliper slightly
Old Nov 24, 2011 | 03:52 PM
JSolo's Avatar
JSolo
Just say no!!!!!
^^You mean when the wheel rotates around the caliper, not when one is turning the steering wheel?
Was it a weight that was hitting the caliper?
Old Nov 24, 2011 | 03:59 PM
NCHIINFMNGR
the spokes hit the caliper, while turning hard the caliper moves to the out towards the spokes of the rim
Old Nov 24, 2011 | 04:16 PM
JSolo's Avatar
JSolo
Just say no!!!!!
I don't see how this could be. The caliper is mounted solidly to the same hub that the wheel is. If you turn the steering wheel to either extreme, the rotor and caliper assembly turns with the wheel. The pads within the caliper move. The caliper itself is fixed, no?
Perhaps a picture would make more sense. I just don't see how a static wheel can fit, but not when you start turning the steering wheel.
Old Nov 24, 2011 | 04:27 PM
NCHIINFMNGR
your calipers have some movement, all i can tell u is that this happens to this cust particular car
Old Nov 24, 2011 | 07:18 PM
myk1013's Avatar
myk1013
interesting....... so it should work with spacers.
Old Nov 24, 2011 | 07:37 PM
mw09g37's Avatar
mw09g37
only the 2009+ 18s will fit the S coupes.
most 18s apparently won't clear the calipers.
Old Nov 24, 2011 | 07:44 PM
myk1013's Avatar
myk1013
I thought 2008 18" = 2009 18" ??
Old Nov 24, 2011 | 07:47 PM
mw09g37's Avatar
mw09g37
nope they're different.
the 2009s (the ones fitted for use with the akebonos) are the webbed spoke ones.
the 2008s are more wishbone 5 spoke.
this is what I remember hearing from previous conversations.
Old Jun 12, 2012 | 05:02 PM
Leadwolf's Avatar
Leadwolf
Would the Akebono work with G37 18x8 +43 wheels? Here an example: https://www.myg37.com/forums/3372313-post1.html
KAHBOOM
Aug 25, 2015 11:05 AM
gcruzjr78
Aug 18, 2015 10:15 AM
RoyalG37
Aug 11, 2015 12:21 PM
TakmaN
Aug 8, 2015 07:47 PM
mbekheet
Aug 4, 2015 04:19 PM
