quick spec advice before I buy
Old Nov 7, 2011 | 11:22 AM
zoop425's Avatar
zoop425
Whats up everyone, im trying to get my exact specs picked out before I buy wheels and tires for next season. I drive an 07 x sedan dropped on bc coils. I am looking to run 19x9.5 +22 all around. My question is will I be able to run this setup without stretching tires allot? I would like the run a practical setup with no more than -2 camber all around and would like to have no gap or tuck a bit of tire. would 245/40/19 be a good size to go with? thanks for the advice. Let me also say That while im definitely going for aggressive, im not going for the poke/ hella flush look considering im in NY and have a driveway that is extremely unfriendly. By that I mean I already have to back in over my grass to get in.
Old Nov 8, 2011 | 06:40 PM
zoop425's Avatar
zoop425
bump ttt
Old Nov 8, 2011 | 07:41 PM
soolman32's Avatar
soolman32
I'm sure the offset gurus will chime soon. What wheels are you getting?
Old Nov 8, 2011 | 07:54 PM
zoop425's Avatar
zoop425
varrstoen 1.1.2s with matte black faces and polished lips I think. I have gone back and fourth a ton of times but I think im going in this direction
Old Nov 10, 2011 | 09:54 AM
zoop425's Avatar
zoop425
bump.. anyone/?
Old Nov 10, 2011 | 09:58 AM
TeRRoRiFiC35's Avatar
TeRRoRiFiC35
well since u are not staggering the fitment, you would need a 225/40 to fit those and those will be stretched. the front will also need negative camber, and the rears will probably be sunk a little. and dont go with Varrsteon, I have seen too many of their wheels break. You bought a sub 40k car, dont buy cheap rims and destroy ur car when the wheel breaks.
Old Nov 10, 2011 | 10:10 AM
zoop425's Avatar
zoop425
you really think I will need that much stretch to run them? And I have never heard of their rims breaking. other companies but never theirs..
Old Nov 10, 2011 | 10:25 AM
jorwick's Avatar
jorwick
Agreed on the strech up front. It can be done without a doubt but that is pretty agressive for a sedan.
Old Nov 10, 2011 | 10:32 AM
zoop425's Avatar
zoop425
so if you think it makes more sense to have that stretch up front, should I just go with 10.5 +22 255/35/19 (rear) and 9.5+22 225/40/19 (front)
My car is AWD
Old Nov 10, 2011 | 11:03 AM
jjasonSU's Avatar
jjasonSU
255 on a 10.5 wheel is a lot of stretch, and u said u didn't want that.
And u also said u aren't staggering bc of AWD. So 255 rear and 225 front tires will not work. They need to be the same width.
Also, I'm n
Old Nov 10, 2011 | 11:12 AM
zoop425's Avatar
zoop425
they dont need to be the same width they need the same rolling diameter.. also i didnt say I wasnt going staggered because of all wheel drive. I wanted to stay square so I can rotate but if the back is not going to fit well then I might as well go staggered.. and 255 isnt that much stretch.
Old Nov 10, 2011 | 11:20 AM
da mayor's Avatar
da mayor
you'll be fine... i had 20x8.5 in the front w/ a 245/30/20 with a +15 offset and still had room for poke, rear was 20x10 and +20 offset w/ 245/30/20 and just barely poked out in the rear.
Old Nov 10, 2011 | 11:41 AM
zoop425's Avatar
zoop425
so which setup would you go with?
RYs06MT
Apr 22, 2016 11:00 AM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
Falker11
Sep 9, 2015 08:53 PM
ZachThomas
Sep 3, 2015 01:40 PM
