inner tire wear on eibach with vossens
so my allignment is whthin specs and my inner tires are wearing VERY quicly im on eibach springs and vossen cv1 32/42. what should i do
I would suggest a camber kit.
WHat size are your wheels and do you have any spacers?
I have Eibach with 20" wheels and I only have minor wear on the inner edge of all 4 tires. This is with about 23-25K miles. Alignment done 2 weeks after putting the wheels on and without spacers, no camber kits however.
Yeah as soon as you adjust anything on the suspension you need to get alignment done. Most likely you altered your toe and that is what is eating your tires. That little bit of neg camber wont chew through tires that fast unless your toe is off. Does the rubber look feathered at all where it is worn?
