Stock Sport rims... with Pro Kit... what size spacers are people using.
Hey, im going to go with a Pro Kit drop, and just wondering what size spacers you guys are using on the sport model.
Let me know if you can recomend any one manufacturer of spacers to get.
H&R
Ichiba
Project Kics
most people are running 20mm all around
i have 25mm in the rear
theres a couple vendors selling spacers, check the wheel n tire section of the vendord
Ichiba
Project Kics
see I have noticed that, my friend has some spacers that look terrible because they stick out past the rim, and the quality of the spacer itself is kind of crap. want to avoid that look
Depends what tire size you run. I have sport 19's with 245/40 front and 275/35 rear. I run 20mm H&R Trak+ DRS spacers in the front and 15mm in the rear. My wheels as a whole sit pretty flush to the fenders and in my opinion, look the best that way.
I've done a lot of research on the forum regarding this topic and I'm going with 15mm all around. From various photos, 15mm seems to get the wheels "close" to the fender with out being completely flush. As an "older" owner, I prefer a more conservative look with my Tanabe drop, plus it will leave space to install slightly wider tires on the stock sport wheels.
I picked up some 15mm spacers from forum members and am waiting for them to arrive. I'll post pictures once the spacers are received and installed.
well then 20mm it is... thanks for your help
post any pictures you have, i live in canada so I need to budget for winter weather and ****ty roads, and that's why i went with pro kit drop.. ill let you know how it works out
No rubbing with that setup? I currently have the Pro kit with same sized Hankook V12s and I'm a little scared about the rubbing...
footballmania32
Dec 6, 2015 07:08 PM
KZK
Canada
Aug 11, 2015 11:16 PM
