quick offset ? on a sedan with eibachs PLEASE HELP
Old Feb 17, 2011 | 01:45 PM
gocats's Avatar
gocats
For all you guys with more info than me on this subject!
Looking to put some wheels on my 11 G37S sedan with eibach pro kit springs. The wheels are 20x8.5 and 20x10 with 245/35 and 275/30 tires.
The offset thats offered on the wheels are +35 on front on +40 on the rear.
Will this work without any issues IE (rubbing, bad tire wear, etc). and will it look OK?
Thanks for your help
Old Feb 19, 2011 | 01:55 AM
gocats's Avatar
gocats
WOW really no one here can help at all??
Old Feb 19, 2011 | 01:58 AM
P Casey's Avatar
P Casey
is ur car an x? what is the bolt pattern of the wheels
Old Feb 19, 2011 | 02:05 AM
gocats's Avatar
gocats
no RWD sport sedan... it is whatever the G calls for 5x140 or whatever it is??
Old Feb 19, 2011 | 02:07 AM
P Casey's Avatar
P Casey
what kind of wheels?
Old Feb 19, 2011 | 02:19 AM
gocats's Avatar
gocats
Helo he851
Old Feb 19, 2011 | 02:30 AM
Doggy's Avatar
Doggy
with those offsets youll be fine. Im lowered on s techs and +20 front and +25 rears
Old Feb 19, 2011 | 02:08 PM
EnviedG35's Avatar
EnviedG35
Those offsets on a lowered sedan will be pretty weak. It will tuck in a good bit in both front and rear. Bolt pattern is 5x114.3, by the way.
Old Feb 20, 2011 | 01:03 AM
gocats's Avatar
gocats
so what would the best offsets be for this setup? should i/ can i/ do i need spacers?
Old Feb 20, 2011 | 09:52 AM
EnviedG35's Avatar
EnviedG35
With those wheels you can run up to about a 15mm spacer in the rear and about a 20mm spacer up front to be flush
G37xhibeet
Nov 15, 2016 09:29 AM
rpm&my_G35
Canada
Nov 7, 2015 05:49 PM
m3clubracer
Aug 19, 2015 03:48 PM
jakebeefsteak
Aug 14, 2015 10:23 AM
GARRYDG07
Aug 11, 2015 08:32 PM
