flat tire
Old Feb 5, 2011 | 09:47 AM
chogrilla's Avatar
chogrilla
flat tire
was just curious..dont know much bout tires..if i were to get a flat tire, would i have to get the same tire that matches my other 3 tires or can i get any tire as long as it matches the required specifications of the car?
Old Feb 5, 2011 | 09:51 AM
beerme986's Avatar
beerme986
you dont have to get all matching tires, but its best to. different tires have different amount of grip and could possibly cause a problem when your slipping
Old Feb 5, 2011 | 01:02 PM
Breitling65's Avatar
Breitling65
If you still on stock tires it would be great moment to replace them with better one. I would, just look tirerack or other places, stock tires are cra.
Old Feb 7, 2011 | 07:44 AM
nydealer's Avatar
nydealer
lots of ppl sell tirs here dont spend 300+ on it just get it use imo... gl
Old Feb 7, 2011 | 09:55 AM
Chico's Avatar
Chico
My opinion is that if you get a flat, you spend $5 to fix it.
Old Feb 7, 2011 | 10:21 AM
rks's Avatar
rks
If the flat is in the tread you can get it plugged for minimal cost. If the sidewall is compromised, then you need a new tire.
Old Feb 7, 2011 | 01:16 PM
BlackGSedaN1027's Avatar
BlackGSedaN1027
You would want to get it patched and plugged. Plugging only is temporary. Do places actually do plugs anymore?
Old Feb 8, 2011 | 09:40 PM
TommyG37xS's Avatar
TommyG37xS
i got a flat front left tire 290 miles into my 2011 g37xs coupe. sidewall popped after pothole, got it replaced for $385. but getting a refund cuz i have the tire dorctor tire and wheel warranty coverage which was $609 for 5 yrs
Old Feb 9, 2011 | 09:50 AM
g37cam's Avatar
g37cam
I plug my own tires and it's not temporary.
Old Feb 9, 2011 | 11:27 AM
breftayka's Avatar
breftayka
It is correct to keep the tires on the same axle uniformed. Basically it is ok to have different tires on the fronts than on the rears. You can get away with mismatching, but I wouldn't do it.
RYs06MT
Apr 22, 2016 11:00 AM
Detailed Image
Lighting/Cleaning Products
Sep 8, 2015 02:39 PM
mmnjtwa
Sep 7, 2015 02:27 PM
Detailed Image
Sep 4, 2015 08:14 AM
