Tire Rotation
Old Jan 18, 2011 | 06:41 PM
TomsG37's Avatar
TomsG37
Tire Rotation
I forgot to mark which summer tires came off the front/back when I put my winter tires on. Which tires usually wear more with AWD, the fronts or the rears? Only 10,000 km (6,000 miles) at change over, so spring would be a good time to rotate positions.
Thanks
Old Jan 18, 2011 | 07:00 PM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
on AWD they should wear out the same, unless you hauling on turns!
Old Jan 18, 2011 | 07:03 PM
TomsG37's Avatar
TomsG37
All tires still have lots of tread, but 2 are slightly more worn.
Old Jan 20, 2011 | 05:29 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
If you have any doubts measure the tread depth and make sure the ones with closest tread are on the same axle.
Old Jan 21, 2011 | 11:56 AM
TomsG37's Avatar
TomsG37
I'm thinking that because the car is mostly RWD, the back tires would wear more than the fronts, so for proper rotation these back tires (slightly more wear), should now go on the front.
I know FWD front tires wear quicker than rear tires, but not sure if RWD (my car) rear tires wear quicker than fronts.
B Feelgood
Sep 1, 2020 02:50 PM
RYs06MT
Apr 22, 2016 11:00 AM
bri
Nov 23, 2015 11:35 PM
mmnjtwa
Sep 7, 2015 02:27 PM
footballmania32
Sep 4, 2015 03:06 PM
