Wheel fitment question?
Old Dec 28, 2010 | 09:51 PM
AroundTheG37's Avatar
AroundTheG37
I've been doing research for the past 2 hours and can't seem to get a straight answer. I was wondering if I could fit a 20x10.5 +25 wheel in the rear with a 285/30/20 tire on a 2008 g37S coupe without any problems. Does this sound feasible? Thanks.
Old Dec 28, 2010 | 10:03 PM
Weiboy718's Avatar
Weiboy718
won't work. i'm at 10.5 + 29 on 285's and rubbing like crazy. i'm also camber in -3.2
Old Dec 29, 2010 | 04:17 AM
JoshLee89's Avatar
JoshLee89
Nope. I have Offset +25 for rear, 20x10.5 and I have 265/30/20. I might go 275/30/20 but then I have to have - camber.
Now I am lowered with S-tech,
Shaved wheel inner liner, bracket.
and stretched tires. which were must.
Camber now at -1.2 at rear
NO RUB
Old Dec 29, 2010 | 07:23 AM
voltic's Avatar
voltic
How are you 265/30 and +25 at only -1.2deg? I'm higher than you, 275/30, +30, no lining, and they can't bring it in more than -3.0deg...
Old Dec 29, 2010 | 08:21 AM
1cleanG's Avatar
1cleanG
NextLevel Performance
what do you mean they can't bring it in more then -3 degree camber? Why can't they? You should always fully be able to adjust your camber with the SPC kit, its just a matter of where you want it set at to avoid rubbing...or if you're more worried about tire wear.
Old Dec 29, 2010 | 08:30 AM
voltic's Avatar
voltic
It rubs at -3.0, if I take it in more it gets bad.
Old Dec 29, 2010 | 08:44 AM
1cleanG's Avatar
1cleanG
damn bro how LOW are you set?? have a pic? This obviously plays a huge role in where you're at...
Old Dec 29, 2010 | 09:04 AM
Kidcane's Avatar
Kidcane
Florida G Club
What are you rubbing? Did you shave/remove the fender bracket?
Old Dec 29, 2010 | 09:47 AM
voltic's Avatar
voltic
Hammered it upward but yeah. I'm about a finger gap tire to fender on all four corners.
Old Dec 29, 2010 | 10:11 AM
GraphiteG37S's Avatar
GraphiteG37S
What else could you be rubbing on? When I saw you car you were a bit lower than me in the rear. I'm running a 285/30 with 0 rubbbing, but my offsets are conservative. Alignment shop should be able to dial in you camber a little more I would think. Is your tire hitting fender or maybe try shaving or removing that bracket completely...
Old Dec 29, 2010 | 10:39 AM
Kidcane's Avatar
Kidcane
Florida G Club
Might also be his Tein are softer then your JICs so he is getting more travel distance. May have add sways to stiffen it up. I know when I fisrt had just my coils set at a soft setting I rubbed quite a bit but then I stiffened them up and added sways and had very little to no rubbing. Not sure what else to do though.
Edit: NM looks like you have Hotchkis so ignor everything I just wrote..lol.
Old Dec 29, 2010 | 10:45 AM
GraphiteG37S
^ I didn't think about that... JICs are pretty stiff and I don't think my offsets will rub either way. Weiboy was running slammed JICs with +29 rear wheels and had to have -3.2 camber, so maybe that's just how it is. I think Voltic is running Hotchkis sways according to his sig.
Old Dec 29, 2010 | 11:26 AM
JoshLee89's Avatar
JoshLee89
Yup I don't know how, but I am at
-1.2 Camber at the Rear
With S-tech
SPC Camber Kits
Brackets Shaved
265/30/20 Tires (one finger gap)
Even With 4 People (Me and three girls)
NEVER EVER RUBBED
is this not normal? lol
Then I am going to run 275/30/20 at the rear
Old Dec 29, 2010 | 11:27 AM
voltic's Avatar
voltic
Hell I don't know. I'm going to trim the brackets down some when I get home today and probably raise the car a bit. Yeah I'm running Hotchkis sway bars.
Old Dec 29, 2010 | 11:28 AM
voltic's Avatar
voltic
With S-tech
Brackets Shaved
NEVER EVER RUBBED
You tell me!
