What size wheel spacer with my volks 19x8.5 +36??
Old Oct 3, 2010 | 04:01 PM
Viper62382's Avatar
Viper62382
Wink What size wheel spacer with my volks 19x8.5 +36??
Id like to kick my front rims out a bit, with the above mentioned size, would I need 5mm or 10 mm with my eibach pro-kit drop?
thanx in advance
also, id prefer not to swap hubs if possible, so if the 10mm will work without a new hub ill do that, otherwise will 5mm work with just a spacer?
Old Oct 3, 2010 | 06:05 PM
ruckus12251985's Avatar
ruckus12251985
im not an offset expert but if also depends on how wide your tires are and what the camber is set at. 5mm is very small, hardly noticable. i basically just did trial and error. I started with 15mm and it was good, then i got a camber kit and anlignment and needed to go up to 20mm. then I wanted the lip to poke out so I got skinnier tires and went with 25 now. (this is my rear wheels)
if you take a picture and post it people will probablly get a better idea of what you need, and it depends on how aggressive you want the wheels to be
Old Oct 3, 2010 | 06:20 PM
G37Sam's Avatar
G37Sam
10mm would make them flush nicely I believe, 15 would be a little on the aggressive side
Old Oct 3, 2010 | 09:07 PM
EnviedG35's Avatar
EnviedG35
My 19x8.5 +35 with 15mm spacer and 245/35/19's
Old Oct 4, 2010 | 03:29 AM
G37Sam's Avatar
G37Sam
Side shot please
Old Oct 4, 2010 | 04:11 PM
Viper62382's Avatar
Viper62382
Are the offsets on sedan and coupe the same?
I am running 245/40/19 on the front with 8.5" width +36. So im assuming 245/35 with 10mm spacer will be ok? Looks like either way ill be needed new hub with longer studs correct?
Old Oct 4, 2010 | 07:12 PM
ruckus12251985
depending if your wheels have the indented spaces on the back of them, you can use the v2 spacers that just bolt on. if they don't have the indented spaces you have to swap the studs, unless you ran 25mm spacers 25mm and up you can use bolt on spacers without the stock studs sticking out past the spacer.
Old Oct 6, 2010 | 07:12 PM
thejumpoff's Avatar
thejumpoff
Sorry OP, I don't mean to thread jack but I'm having the same issue with my fronts too. I was wondering what spacer size would work best for me?
Fronts are 19x9.5+38 245/35/19
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
news1213
Dec 16, 2015 11:06 AM
connoisseurr
Sep 20, 2015 04:14 PM
MJ HINX
Aug 23, 2015 10:30 PM
