Picking up sport coupe wheels for g37xs? Would they mess with the ride?
Old Sep 7, 2010 | 10:56 AM
slimlma04's Avatar
slimlma04
Cool Picking up sport coupe wheels for g37xs? Would they mess with the ride?
Hey guys im picking up sport coupe 19"s for my g37xs sedan, would i have a problem with fitment, and would it harm the ride quality?
Old Sep 7, 2010 | 11:05 AM
da mayor's Avatar
da mayor
itll feel stiffer on bumps
Old Sep 7, 2010 | 11:49 AM
terfer's Avatar
terfer
They look great on the sedan. I had them on mine! No issues!
Old Sep 7, 2010 | 12:09 PM
slimlma04's Avatar
slimlma04
Thanx... Caught an awsome deal on them 900 with tires, 80% thread left in near mint condition
Old Sep 7, 2010 | 12:16 PM
xBLACKMAM8Ax's Avatar
xBLACKMAM8Ax
If possible could somebody post a pic of these on their sedan? I am thinking about doing the same but would like to see how they look on a sedan. Thanks in advance.....
Old Sep 7, 2010 | 01:06 PM
DocJohn's Avatar
DocJohn
G-DOG
Aren't the 19" sport coupe wheels staggered? Personally I would not use a staggered wheel set-up on an AWD (G37x).
Old Sep 7, 2010 | 01:14 PM
rohardi's Avatar
rohardi
Agreed. If you do a search, there are a few threads reguarding the coupe sport 19's on the AWD sedan. You would need 4 fronts or 4 rears to be compleatly safe.
Old Sep 7, 2010 | 01:34 PM
slimlma04's Avatar
slimlma04
What do u mean four fronts or four rears?
Old Sep 7, 2010 | 02:02 PM
xixonmn's Avatar
xixonmn
I think he means non-staggered (4 identical wheels) setup.
Old Sep 7, 2010 | 03:08 PM
JohnEnglish's Avatar
JohnEnglish
The sport coupe wheels are 225 front and 245 rear. Since they're staggered their overall height is slightly different. This doesn't matter with the RWD coupe but with the AWD sedan the difference in overall wheel height will mess up the AWD system since the front and rear wheels will be rotating at different speeds. The AWD systems assumes that under normal conditions the front and rear wheels should be rotating at the same speed.
What you need to do to prevent this is either get 4 front wheels from a sport coupe or 4 rear wheels so the wheels are all the same size.
Old Sep 7, 2010 | 03:14 PM
slimlma04's Avatar
slimlma04
I got u, where the hell am i gonna find 4 front or 4 rear lol... I really love those wheels
Old Sep 7, 2010 | 03:19 PM
JohnEnglish
Assuming you don't want to buy them from the dealer, you can find people selling fronts and rears on eBay and Craigslist. You can also check out different forums and find someone else wanting to buy sport wheels for an AWD vehicle. That way you can buy two sets, split the cost and the one of you takes the fronts and the other takes the rears.
Old Sep 7, 2010 | 03:21 PM
slimlma04's Avatar
slimlma04
Thank you, thats a good idea
Old Sep 7, 2010 | 05:30 PM
Jayhawk815's Avatar
Jayhawk815
There is a lot of misinformation around here. You can run a staggered setup with AWD. True, you want the overall diameter of your front and rear tires to be as close as possible to being the same, but not being perfectly exact won't ruin your drivetrain.
Take for example the staggered sport wheels. Throw on the stock 225/45-19 tires on the front coupled with 245/40-19 tires on the rears, and you have an overal diameter difference of .3", or .9%. Again, the closer, the better, but this kind of variance can easily happen with uneven tire wear. Obviously you also want to rotate your tires, but not doing so won't ruin your AWD drivetrain.
And yes, do some more research. There are quite a few AWD G owners that are running staggered setups without any problems. All of the naysayers I've seen are doing so based on speculation and assumptions.
Old Sep 8, 2010 | 02:11 AM
slimlma04's Avatar
slimlma04
so all in all, can you do it with 245/225 set up?? or will it cause a problem with the awd system?
