Quick tire size help!!!!
Old Jun 23, 2010 | 08:37 PM
GraphiteG37S's Avatar
GraphiteG37S
Question:
Im replacing my tires. Currently in the rear I'm running a 10.5" rim with a 275.30R20 tire. I have a G37S coupe lower with eibach pro kit.
I wanna gain some sidewall in the rear. Do you think a 275.35R20 will clear without rubbing issues with eibach drop? What about 285.30R20?
Old Jun 23, 2010 | 08:39 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
Those both SHOULD clear on Eibachs. If you hit a big dip you might rub just a little bit but it shouldn't be a problem
Old Jun 23, 2010 | 08:50 PM
Loi's Avatar
Loi
I got a pair of 275/35/20 Pirelli waiting in my garage. Can't wait to see how it'll look! I think the 275/30 tires are too thin.
You shouldn't have any issue with either. If so, it's nothing major.
Old Jun 23, 2010 | 09:19 PM
WPPJR30's Avatar
WPPJR30
Offset of your wheels?
Old Jun 23, 2010 | 09:32 PM
Loi's Avatar
Loi
Think he got the GT-30 +35F +37R , same wheels as me.
Old Jun 23, 2010 | 11:08 PM
GraphiteG37S
I've got GT-7 actually with the same offsets as Loi.
Got 255.35r20 upfront and those clear great. I'm worried about going larger in the rear.
Old Jun 24, 2010 | 01:10 PM
ucla bruin's Avatar
ucla bruin
Since you have 255/35 in the front, I would go with 285/30 in the rear. It's a closer match to the front than 275/30. What kind of tires are you getting? If it's not S drives, it might be ok. If it rubs, you can always shave down the inner lining. How much negative camber?
__________________
Old Jun 24, 2010 | 02:30 PM
WPPJR30's Avatar
WPPJR30
I have 20x9.0" (+25) Front; 20x10.5" (+35) Rears with 245/35 and 275/30 On Eibach Pro-Kit and I rub. Just saying...
Mattlorentzoe
May 24, 2021 08:49 PM
G37xhibeet
Nov 15, 2016 09:29 AM
jayrdong
Oct 25, 2015 10:00 PM
Hiryuu
Aug 7, 2015 07:08 PM
Rubyq60
Aug 3, 2015 10:36 PM
