Braking on highway
Old May 12, 2010 | 09:18 PM
pro-gadgeter's Avatar
pro-gadgeter
Braking on highway
When i apply the brakes on the highway, the car steering starts vibrating and so does rest of the car. Is that normal?
Old May 12, 2010 | 09:32 PM
TomieG's Avatar
TomieG
Could be warped rotors. Theres a tsb for this. Bring it into the dealer.
Old May 12, 2010 | 11:03 PM
owslystnly's Avatar
owslystnly
^ second what he said. Definitely sounds like warped rotors.
Old May 12, 2010 | 11:23 PM
ozzypriest's Avatar
ozzypriest
no. I had that as well. Dealer resurfaced the front rotors, and all is well. Go now, though, as the warranty on brakes and rotors expires around 12k, or something similar...
Old May 16, 2010 | 08:30 PM
nitromt's Avatar
nitromt
Physically warped rotors are extremely unlikely. It is more probable that the cause is because of uneven pad deposits on the rotors resulting in increased runout. Trying the bedding-in procedure and if that does not make the problem go away, consider getting the rotors turned as a last resort.
Old May 16, 2010 | 11:17 PM
beerme986's Avatar
beerme986
+1 to what everyone has already said. if dealer doesnt fix it, just an excuse to get some slotted rotors
Old May 16, 2010 | 11:59 PM
15951's Avatar
15951
Machining the rotors should be your last step, as it removes material, makes them more susceptible to brake judder in the future, and increases the likelihood that you'll have to replace the rotors when you need to replace the brake pads.
Ever take your car to a tunnel wash after it's been driven for awhile? Very hot rotors + cold water has been known to cause warping. So has overtorquing the lugnuts - was the car serviced lately?
The pad transfer idea, above, is a good one and can be addressed by following the bedding procedure.
Old May 17, 2010 | 10:36 AM
Triple_X's Avatar
Triple_X
had the same problem, they resurfaced and they look and perform like new again. Wasn't covered under warranty though, although I did overtorque some lugs and needed two screws replaced from being stripped.
Old May 17, 2010 | 11:09 AM
nitromt's Avatar
nitromt
It is 99.9% likely that this is a COMPLETE waste of money.
Only reasons why someone would need slotted are:
-They are tracking their car 100% of the time.
-Their pads are likely to gas.-
-They are tracking their car in the rain.
-The bling factor.
Old May 17, 2010 | 11:10 AM
nitromt's Avatar
nitromt
Ladies and gentlemen, I would like to welcome our "mythical garage gorilla" to this forum.
Seriously, how much torque did you apply to manage to strip two lug nuts?
I usually use anywhere from 70-85ft.lbs of torque when I'm torquing down the lug nuts.
Old May 17, 2010 | 04:27 PM
Triple_X's Avatar
Triple_X
lol I had it set to 90...but apparently I cross threaded and didn't realize until it was time to get those bastards off
Old May 18, 2010 | 12:01 AM
Sunny G's Avatar
Sunny G
There is a TSB for that and the dealer should fix it for free.
Old Jun 11, 2010 | 10:07 PM
pro-gadgeter
Sorry I haven't responded in such long time. I need to get my oil changed for that anyways so I'll just mention it to them. Hopefully they cover it under warranty or else i'm going to get pissed
Old Jun 12, 2010 | 09:55 PM
ozzypriest's Avatar
ozzypriest
hey - what's your current mileage? You to get up in there.....
Old Jun 13, 2010 | 12:27 AM
surfjax87's Avatar
surfjax87
It should be under warranty seeing as the warranty coverage is 4 yr/60k miles. Talk about 12 month/12k miles for brakes is total bs, I just read the entire limited warranty. It sounds like a scam for dealers to charge for warranty work.
The only items that come with a 12 month/12k miles warranty are replacement parts and accessories from infiniti excluding audio components.
Plus, the tsb released august, 2009 says 2007-2009 sedans are affected. So if you bought an 07 and found out about the tsb in 09, then you're s.o.l. if the coverage is 12 months. It would basically be infiniti telling you that they know something is defective in your car, but they won't pay to fix it.
