Whats the best spacer size for 19"OEM wheels/tires?
Old Apr 8, 2010 | 09:54 AM
HamstersG's Avatar
HamstersG
Think twice before going with 25mm. There is a pic on here somewhere and it looked not to good.
Originally Posted by cereal2k
So just to confirm, any spacer will do but getting one with a hub centric ring is recommended? I'm keeping my stock wheels but thinking of going 20 and 25.
Old Apr 8, 2010 | 10:04 AM
marcelo19lp's Avatar
marcelo19lp
WOW widdles, your car is very nice! I have platinum graphite, never taught how nice it looks with the wheels that color, and with 20mm spacers. What tint percentage do you have? Do you have cambers and all that stuff, or just eibach and are your tires original size. I dont have the tires like you do. I have the original tire sizes. Somebody...humm lets see GT racing said that with 15mm, his tires stick out of the fender, he must have different tire sizes. So with 15mm definately no rubbing with eibach, no cambers, and with 20mm some possible rubbing with eibach, no cambers with all the original tire sizes from potenza. By the way BLACKJACK how much did you pay for your tints? Thanks.
I plan buying the ibicha bolt on spacers, they come already with hub centric ring, if im not mistaking, correct?
BUMP
Old Apr 8, 2010 | 12:29 PM
whiddles's Avatar
whiddles
sorry its not my car man. i just found it for you. its wakeboards car from here somewhere
Old Apr 8, 2010 | 10:47 PM
csnpsu's Avatar
csnpsu
Sorry but i am new, what do spacers do?
Old Apr 9, 2010 | 12:40 AM
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
The vert has a wider track in the back so I'm thinking it would be fine with the stockies.
Old Apr 9, 2010 | 12:56 AM
cereal2k's Avatar
cereal2k
They push the wheel further out from the body of the car mostly for looks and handling. Some more info here
How Do Wheel Spacers Work? | eHow.com
Old Apr 9, 2010 | 08:18 AM
HamstersG's Avatar
HamstersG
Go out and measure and make sure as +1" is a lot. Take a 1" piece of styrofoam and tack it on, push it around to see where you are going to potentially rub, etc. Better than guessing and wishing you had gone with something smaller.
Old Apr 9, 2010 | 09:50 PM
cereal2k's Avatar
cereal2k
Good tip. The rear won't be dropped in my case just yet until there are rear springs or coils made for the vert.
Old Apr 10, 2010 | 12:52 AM
HamstersG's Avatar
HamstersG
Oh....without a drop, pushing the wheels to the edge can look funny. At least it does to me. But if you go with 15-25mm bolt-on, then they are easy to take off if you decide to wait until you get some springs/coils.
Old Apr 19, 2010 | 05:48 PM
Jereguy's Avatar
Jereguy
anyone have pics of the person with 25mm?
I'm looking to do this with my g 20 front and 25 rear perhaps? I'm running tanabe coils and Toyo T1R's 275 in the rear.. Or is safe bet go 20 all around ?
Someone mentioned you don't need an alignment after putting spacers? Really?
Old Apr 20, 2010 | 09:38 AM
marcelo19lp
BUMP BUMP.
With 15mm around and the 245/40 and 275/35 with eibach pro, will that cause any rubbing issues or just stick it safe with the original tire sizes of 245/45 225/40+15mm all around. By the way, how much exactly does having bigger shoes impact your MPG, not thats a big deal, but kinda curious? If not getting the bigger shoes, and just sticking to the 15mm with eibach, will that have an impact on MPG?
Old Apr 20, 2010 | 09:44 AM
TheGspot37s's Avatar
TheGspot37s
Originally Posted by marcelo19lp
BUMP BUMP.
I have 245F/275R and I am running 20MM in the back and 15MM in the front. The wheels fit perfectly flush and I haven't experienced any rubbing sense I installed them. Check out my thread for pics (page 3): https://www.myg37.com/forums/wheels-...-woohoooo.html
Old Apr 20, 2010 | 07:01 PM
Jereguy's Avatar
Jereguy
bumpity bump bump
Old Apr 20, 2010 | 07:09 PM
  #29
marcelo19lp
Nice pictures. So so far no rubbing WOW! I was reading and from all the search, I was leaning to 15mm ALL around to keep it safe, no cutting fenders etc. As well as keeping the orignial tire sizes. Does anybody have any pictures with 15mm all around with original tire sizes and if possible with the 245/40 275/35. BUMP BUMP...
Old Dec 5, 2011 | 02:25 PM
  #30
mistuhlayzee's Avatar
mistuhlayzee
Question regarding wheel spacers and g35 h techs
Hi everyone, sorry for the thread revival, but I've been searching and have had no luck finding out an answer. I just recently purchased a g37, and was planning on lowering it with g35 h techs and getting 20mm spacers all around. Would there be any issues or rubbing or camber? On my previous g35, I ran 350z htechs and 27mm around was fine. Would the same be for my g37?
