staggered rims and AWD
Old Mar 8, 2010 | 08:30 AM
  #31
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
Originally Posted by 09xs
well if its 225/45/19 (fronts) 245/40/19 rear - your saying dont do it bc there will be damage done?
Correct. Diam diff is three tenths of an inch, with the front being the taller tire. Doesn't sound like much but over time can be enough for trouble.
Old Mar 15, 2010 | 09:03 PM
  #32
freesurfer's Avatar
freesurfer
Simple solution, use 215/45/19 (fronts) 245/40/19 (rears) for a overall height difference of less than one tenth of an inch. The difference in rolling circumference is less than half of one percent. Insignificant. And the rear tire is larger than the front tire, the way it should be.
Yes I'd prefer zero, but suddenly driving staggered rims on a G37x doesn't sound quite as scary. Just use 215mm wide front tires.
Old Jul 16, 2010 | 03:02 PM
  #33
GianG37x's Avatar
GianG37x
Originally Posted by IgS
I wouldnt recommend running tires that are significantly different between front and rear.
Im actually running the coupe 19s on my X with 245/40/19 tires all around and have had no issues so far. Rolling diameter is the same.
hope that helps
can i see a pic of the coupe x with the 19s since i have the coupe x with 18s and id LOVE to see how it looks. thank you.. u can email me at bmwbusiness007@aol.com thanks
Old Jul 18, 2010 | 07:26 PM
  #34
Clutchr6's Avatar
Clutchr6
i would also like to see pictures as well please post them
Old Jul 19, 2010 | 02:22 PM
  #35
IgS's Avatar
IgS
I actually have the sedan X, not the coupe. I would imagine that the X coupe with the 19's would look almost the same as the regular coupe S but would sit just a tiny bit higher.
Old Jul 19, 2010 | 08:49 PM
  #36
Clutchr6's Avatar
Clutchr6
i just want to see after market wheels on the awd coupe
Old Jul 22, 2010 | 06:02 PM
  #37
Clutchr6's Avatar
Clutchr6
Neal is this statement correct?
Old Jul 22, 2010 | 06:08 PM
  #38
Neal@tirerack
Of all the tire brands we carry none I have come in a 215/45-19. Wonder if the FREE meant 225.
Old Jul 22, 2010 | 08:34 PM
  #39
Clutchr6's Avatar
Clutchr6
if it is 225 what is the rolling diameter
Old Jul 23, 2010 | 05:38 PM
  #40
Neal@tirerack
The 225/40-19 is 27" tall.
Old Jul 23, 2010 | 11:51 PM
  #41
Clutchr6's Avatar
Clutchr6
and what is it for 245/40/19?
Old Jul 24, 2010 | 09:40 AM
  #42
Neal@tirerack
26.7" would be a tad shorter than the front tire.
Old Jul 24, 2010 | 10:43 AM
  #43
FlyingLumpia's Avatar
FlyingLumpia
I have a 04 awd and I am running staggered. Run 225/40 f and 255/35 no problem what so ever. I even drove from Seattle to Cali, got a flat and ran a 235/50/17 spare and had no problems.
Old Jul 25, 2010 | 08:26 AM
  #44
Clutchr6's Avatar
Clutchr6
19's or 20's ?
Old Nov 20, 2010 | 08:36 AM
  #45
jarena2104's Avatar
jarena2104
i got a 2007 G sedan X and i got the vossens cv1's 20x9 front 245/35/20 and 20x10.5 285/30/20 and i have no problems except for when coming off a pkwy ramp reall hard on the turn my rpm's are getting stuck as though my awd system is leveling the power to the wheels until my car goes flat again. this is driving me crazy but other than that i have no problems
