G37s sedan tire rotation
Old Feb 14, 2010 | 03:55 AM
xlacrimx's Avatar
xlacrimx
I just found out today that the front and rear tires are different sizes. How would I go about rotating them? And if I don't rotate them, how long will the tires last? I drive fast and floor it a lot, and sometimes even drift a little.
Old Feb 14, 2010 | 09:07 AM
2009Black's Avatar
2009Black
Yup. You basically can't rotate tires on the S sedan. The stock tires seem to last people 15-20k depending on your driving style.
Old Feb 14, 2010 | 11:22 AM
You can side-to-side rotate since the tire orientation on the rim is the same (not directional, just "outside" stamped on the tire). This will give slightly more tread life, but like mentioned don't expect more than 20k from summer grip tires.
Old Feb 14, 2010 | 11:38 AM
dkmura's Avatar
dkmura
20 Year Member
This also means you have to dismount and swap directional tires and then remount and rebalance them to get a bit more life from them. I'd suggest you use that effort to instead monitor tire pressures and treadwear carefully (weekly) to maximize tire life.
I'd further suggest that the rear tires will need replacing sooner than the fronts, no matter what you do.
Old Feb 14, 2010 | 01:18 PM
The Potenzas aren't directional, just outside bias, so you can go side to side w/out remounting.
Old Feb 14, 2010 | 09:22 PM
Silver37's Avatar
Silver37
Great tip...have you noticed any better wear or performance by rotating them?
Old Feb 14, 2010 | 11:31 PM
We sold our 07 w/ staggered wheels but did rotate side to side & got about 23k on the Potenzas before changing them, the rears were down to the wear bars. I'm guessing we added about 1500 miles by doing it, but not really conclusive~tires were very evenly worn by doing it though so I assume it's a good thing to do
WolfSongX
Car Care & Detailing
May 10, 2017 07:26 PM
drewfinity
Aug 20, 2015 08:17 PM
dAgent
Aug 19, 2015 06:49 PM
HB4LTHR
Aug 9, 2015 11:12 AM
