Dang! Aggressive offset destroyed bumper bracket, anyone else deal w/ this?
This is the bracket that holds up the rear bumper cover to the upper sheet metal. Forged shaved it down for me on the install but it still rubbed and finally went. Anyone else deal with this? Can anyone think of a simple solution or am I gonna have to take this thing in to a body shop? (BTW, I'd really love a solution where I could get rid of the bracket all together so I don't have to rub any more).
Here's the best I could do on pics:
This this break because of shaving it down? I think you may have to go to a body shop to get that repaired, they can probably make something custom that won't rub with the tires and still do it's job.
It was shaved down but that's not why it broke, it broke b/c the tire hits it with any significant bump in the road.
There actually seems to be another attachment point not too far down the seam. I was worried when it did go that the bumper would sag but at this point it seems the corner just pulls out at speed. I was wondering if I could rough it up on the inside and lay a couple layers of fiberglass and resin down but I only have limited experience with bodywork and such.
Someone tell Stoof to get in here then!
On a plus side, I just realized that I don't have a rub anymore which is great. Does anyone know if there is some kind of epoxy putty that I could flatten over the inside seam that would bond to the sheet metal and plastic (or whatever the bumper cover is made of)?
Mine are 22 in the rear 26 in the front (offset). This was one of the early ones Sharif did on the g37s and I think he was playing mad scientist on seeing how much he could go without hitting the fender. He was right and they tucked in but that bracket was a little too much though and I had rubbing over rough stuff. Funny thing is that since the tires "uninstalled" the bracket, its been a whole lot nicer...no worries I haven't even done anything about the missing brackets and I'm not having any bumper hang issues or anything.
i recently shaved off my bumper brackets and it rubs alot less. you can try using 3m double sided tape to hold the bumper to the quarter panel together. that's what i did and it's holding up good. give that a try!
that's a pretty aggressive setup you're running without stretching your tires. good job! what's your camber set at in your rears?
I am gonna try some kind of tape...I have some of that sticky metal-sided sound deadening stuff that I was thinking of trying.
In case this helps anyone, here is what I ended up doing:
1: Grind/cut the remains of the braket off
2. De-burr, paint sheet metal
3. There is enough material left behind the original bolt bracket position the sink a good sheet metal screw through the bottom and up into the sheet metal: pre-drill and sink screw.
Here is a pic, panel alignment is now perfect and no rubbing:
