TMPS Lite
Old Dec 30, 2009 | 05:00 PM
pdarby's Avatar
pdarby
TMPS Lite
Driving around and the TMPS lite came on. Stopped at a gas station, checked the manual and aired the tire back up. Book says drive over 16 mph and the light will go out. But it didn't. Any ideas? Might just have to take it to the dealer.
PD
Old Dec 30, 2009 | 06:09 PM
EnviedG35's Avatar
EnviedG35
Did you check your spare?
Old Dec 30, 2009 | 07:19 PM
G37Sam's Avatar
G37Sam
I didn't know the spare was hooked up too..
I'd re-check the tire pressures and drive around for a while.. if it still comes on then you have a problem
Old Dec 30, 2009 | 09:44 PM
Chekov's Avatar
Chekov
Senior Citizen
The spare is not monitored by the TPMS (but it‘s a good idea to check it once in awhile anyway). Make sure you put enough air in all four tires; then drive over 16mph as suggested. If the light stays on, a trip to the dealer is warranted.
Old Jan 3, 2010 | 07:27 PM
pdarby's Avatar
pdarby
Well I double checked the manual and the tire pressures all around, and the lite is still on. It never did flash, that I saw, like the book says if there's a problem, its just on steady, all the time. Must be a bad sensor, and dealership here I come. They will probably bust my ***** about the 275's on the back, AGAIN. But at least its not the tires that is a problem.
ap0c0lypt1c
Group Buys
Aug 15, 2013 04:21 PM
KZK
Canada
Apr 5, 2012 02:44 PM
