Help Offset help needed
Old Dec 7, 2009 | 01:10 AM
Gunit37's Avatar
Gunit37
Arrow Offset help needed
Are they too aggressive for G37 Coupe? I don't wanna cut and trim anything. Don't wanna run spacers either.
19x8.5 +15 front
19x10 +20 rear
Thanks~!
Old Dec 7, 2009 | 03:06 AM
G37Sam's Avatar
G37Sam
What are you dropped on?
Old Dec 7, 2009 | 03:22 AM
Gunit37's Avatar
Gunit37
Not yet..probably Eibach down the road.
Old Dec 7, 2009 | 03:32 AM
G37Sam's Avatar
G37Sam
Unless you run some -ve camber might look funny
Old Dec 7, 2009 | 04:29 AM
gan78mao's Avatar
gan78mao
u should be fine.
give it some negative camber in the rear and u shouldnt rub at all.
are these the chikara wheel specs? seems liek it.
Old Dec 7, 2009 | 04:41 AM
sbmwg37s's Avatar
sbmwg37s
Those are not too aggressive, but aggressive enough.
Negative camber or possibly mild stretched set up will be recommended.
Old Dec 7, 2009 | 04:49 AM
Gunit37's Avatar
Gunit37
Thanks Sam and gan78mao. How much negative in the rear? I drive my car alot so I don't want anything crazy... dmn bro, you're right, these are the chikara wheels. Just waiting to see their new finishes!
Old Dec 7, 2009 | 05:02 AM
G37Sam's Avatar
G37Sam
Are you guys sure +15 in the front won't be too much? That's like adding a 30mm spacer to the front wheel?
I saw pix of a stock G with a 25mm spacer in the front and they stuck out just a little, stock height & camber
Old Dec 7, 2009 | 06:32 AM
gan78mao's Avatar
gan78mao
+15 in the front is fine!
my first set of AMEs I was running 19 by 9 and 19 by 10 with +15 all around.
before the drop, it looked retarded, but once the drop came, it was perfect. so I would say with a +15 on an 8.5 u should be fine.
you can also PM Geooooooh. He has those wheels on his car he should know how much negative camber u might need.
Also remember to have minor stretch or run tires that have round tirewalls instead of meaty tires.
Upser88
Aug 20, 2015 08:30 AM
gcruzjr78
Aug 18, 2015 10:15 AM
jakebeefsteak
Aug 14, 2015 10:23 AM
pledes23
Aug 11, 2015 10:54 AM
Abramite
16
Aug 8, 2015 08:35 AM
