Volk formula lugs suckkkkkkkkkk
Old Nov 13, 2009 | 04:29 AM
ucla bruin's Avatar
ucla bruin
Have you heard of Grab-it?
http://www.youtube.com/watch?v=InGiAr3CPSw
__________________
Old Nov 16, 2009 | 09:32 AM
Triple_X's Avatar
Triple_X
fyi! they are made out of metal. just the part where you put the key in is plastic.(which sucks) i broke mines in the second day of owning it and tell you the truth it's sitting in my garage collecting dust now. i replaced them with the project kics neo chrome(thanks to Lou@amplified)
i had to use a thin flat head screwdriver to pry the end and use a sharp nose plier to pull it out. looks good but not very made.
yea man I wish I knew this before spending money on them. They do look great and are a great deterrent, but the key is useless and should have been thought through more...
Old Nov 16, 2009 | 09:35 AM
Triple_X's Avatar
Triple_X
YouTube - GRABIT (starring Billy Mays)
hmmm that is a pretty nice tool, but I'd rather just break the inserts off with a screwdriver/hammer instead of buying it just for that reason.
Old Nov 16, 2009 | 09:37 AM
Triple_X's Avatar
Triple_X
ok so Friday morning I had the car towed to the dealership to hopefully have the tire plugged and then worry about removing them another time. 4.5 hours later they end up plugging it and I'm on my way with only a scraped front bumper from the tow truck, that stupid bastard.
I then bought an allen wrench key and it fits into the insert and removes them easily so I am good to go now. I will just buy a new tire next spring and am planning on changing back to stock for winter anytime now.
so anyone who has or is going to have the volk formula lugs....immediately throw the plastic key away and keep metal allen wrench in your car.
Old Nov 16, 2009 | 10:39 AM
oOmikeyboy's Avatar
oOmikeyboy
Yep, i stripped my plastic key on the 2nd use. you'd think that VOLK of all companies would put in a higher quality allen key for their lugs.
Old Nov 16, 2009 | 03:28 PM
WhosUrBuddiee's Avatar
WhosUrBuddiee
Ive never had a problem with mine.
Old Nov 16, 2009 | 08:09 PM
jran76's Avatar
jran76
I actually think they made the plastic key like that for a reason. I think they did it to prevent people from over-torquing the center insert. With a normal allen wrench you can torque it well beyond what it should be. With the small plastic "key" you can only get it so tight. The fact is the center insert does not need to be overly tight, or you will have problems getting is out later. The plastic key is a pretty good way to proof it against that happening. If you strip, or break, the supplied key, you are over-tightening the center insert....
Old Nov 16, 2009 | 11:07 PM
oOmikeyboy's Avatar
oOmikeyboy
perhaps. I was more concerned it would unscrew itself and get lost as i'm driving. i don't think they sell replacement inserts?
Old Nov 16, 2009 | 11:12 PM
myk1013's Avatar
myk1013
Sad to hear your problems with those lugs. I can't justify paying $150+ for those things. I'm completely happy with my Muteki's.
Old Nov 17, 2009 | 12:43 PM
JKashat's Avatar
JKashat
I had to some of mine out b/c the stripped. It was pretty scarey trying not to scrape a wheel. I started out with a small drill bit and kept going bigger until the broke and then used pliers to get them out and a air gun for the metal shavings. I was supposed to send them back to Mackin Industries for replacements but lost them, lol. I ended up ordering a full second set because they were just so damn cool looking, which I never even used. Next season after I put them back on (already took rims/tires off) I'll run them w/o the caps. They'll get a little surface rusting but that's better than then seizing on the lugs or stripping out again IMO.
Old Nov 17, 2009 | 01:28 PM
How about using a little thread lubricant or anti seize compound on the threads of the insert and not torquing the bejeebers out of them? They should come out easily then. Hopefully...
Old Nov 17, 2009 | 01:43 PM
Triple_X's Avatar
Triple_X
thanks for the suggestion, the metal allen wrench is capable of taking them out so I should be all set to switch my tires out for the winter this weekend.
Old Oct 5, 2019 | 02:46 PM
Xcalibur's Avatar
Xcalibur
I know this is an old post and I haven't posted in awhile but I'm going to warn anyone from buying these expensive so called "professional lug nuts". Volk/Rays should be sued for this BS! Forget the little cute cap that strips. Thats easy, drill a pilot hole and use a screderiver.
The main issue is each lug is a key and they f**king strip! EVEN IF HAND TORQUED TO SPECS!!!! I've had this an issue both times where I had to have them drilled or over socket size used to remove them. STAY CLEAR AWAY FROM THIS GARBAGE!!!! Shame on them for not pulling this off the shelves.Oh yeah no one will get your wheels off including you the owner haha!
Stevolkz33
May 28, 2016 02:36 AM
Depravity
Oct 16, 2015 01:37 PM
djdiskino
Oct 7, 2015 08:31 PM
*ICE*
Oct 5, 2015 03:05 PM
