how do i find out how much to torque this nut on the rear axle?
Old Oct 26, 2009 | 04:00 PM
jasyn's Avatar
jasyn
so i'm doing a little project to fit some rims .. i'm going to have to shave down the rear axle a bit to the point where the cotter pin is so just a precautionary i plan on putting thread lock on the thread as well as the inside of the bolt to make sure it stays in place.
would anyone know the torque value for this nut that i've pointed out with the arrow?
Old Oct 26, 2009 | 04:04 PM
RTFFSM!
I can't believe you'd undertake such a modification yourself without having the FSM available to you. The torque value is 177 ft./lbs. for that nut.
Old Oct 26, 2009 | 04:12 PM
jasyn's Avatar
jasyn
RTFFSM!
yah i probably should get the service manual huh? lol thanks!
Old Oct 26, 2009 | 04:19 PM
I wouldn't screw with something like that without if for sure.
Even though you aren't a noob, I'm going to spoon feed you because I'm intrigued by your project.
FSM Sticky
Old Oct 26, 2009 | 04:46 PM
jasyn's Avatar
jasyn
FSM Sticky
greatly appreciate it .. just to throw it out there .. would u happen to know if there are any covers that go over the rear axle section so dust/rocks don't get into the nut? been trying to search all over and all i can find are motorcycle parts.
Old Oct 26, 2009 | 05:05 PM
Not anything model specific for sure. But I bet if you searched enough you might find a rubber boot that's the right diameter and depth to fit over it that would work. Take measurements then search the web.
If not, it should be easy enough to fabricate something yourself, even if it's crude and elementary. How about a thick piece of rubber (thicker than a balloon) cut to shape and secured with a heavy rubber band or something similar? I know it sounds ghetto as hell, but you get the idea. As long as it works and would serves the purpose it shouldn't matter how it looks because the wheel is covering it anyway.
GrayG37
Feb 10, 2022 11:52 AM
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
gcruzjr78
Aug 18, 2015 10:15 AM
xxg00w0
Aug 14, 2015 07:15 PM
