Help 19" offsets Question on G37s
Old Oct 10, 2009 | 03:21 PM
yakuzapop's Avatar
yakuzapop
To: who are Wheel Experts.
Will this wheel set fits on my G37s?
Clears Brake? both front and rear ?
Might rub?
Front: 19”x9.5” +30mm
245/35/19
Rear: 19”x10.5” +24mm
275/35/19
Thanks for help
Old Oct 10, 2009 | 04:00 PM
Weiboy718's Avatar
Weiboy718
Might rub?
245/35/19
275/35/19
Thanks for help
those offset will work but you'll have to run some stretched tires in the rear or more negative camber. and it'll clear your brakes.
Old Oct 10, 2009 | 06:46 PM
yakuzapop's Avatar
yakuzapop
Thanks Weiboy718.
Old Oct 13, 2009 | 03:04 PM
yakuzapop's Avatar
yakuzapop
Front: 19”x9.5” +23mm
245/35/19
Rear: 19”x10.5” +23mm
275/35/19
Is this set gonna clear brake?
Old Oct 13, 2009 | 04:13 PM
yakuzapop's Avatar
yakuzapop
Which one loook better for our G37 ?
Volk GTS or GT-7 ?
Old Oct 13, 2009 | 04:32 PM
ShanesG's Avatar
ShanesG
^You need to know your pad height and what clearance you need to find out if it's gonna clear your brakes. If you have the non-sport brakes 99% they will fit. With the akebonos you need a higher pad. Offset has nothing to do with brake clearance!!!
jakebeefsteak
Aug 14, 2015 10:23 AM
GARRYDG07
Aug 11, 2015 08:32 PM
pledes23
Aug 11, 2015 10:54 AM
Abramite
16
Aug 8, 2015 08:35 AM
