Uneven Tread Wear
Old Aug 19, 2009 | 02:11 PM
Foresite's Avatar
Foresite
Uneven Tread Wear
I have had my Nitto INVOs for 7 months now and I notice that they are done. What I also noticed is that they (especially the back tires) seem to have worn out unevenly. One side of the tread still has something while the other side is gone. When I get new tires, how do I make sure that doesn't happen again? Is it alignment? I can't insert pictures from where I am but I will get them up later today.
Old Aug 19, 2009 | 02:44 PM
ReddieG37's Avatar
ReddieG37
is your car lowered? if your car is lowered, this will make your wheels camber in (negative camber) which will make the inner parts of the tire to wear faster. Alignment will help but if you are lowered, you might need to invest in aftermarket camber arms to fix the problem.
Old Aug 19, 2009 | 02:53 PM
ucla bruin's Avatar
ucla bruin
If you're lowered on Eibachs, you don't need camber kit, just alignment will do.
__________________
Old Aug 19, 2009 | 03:38 PM
Triple_X's Avatar
Triple_X
if you need a rear camber kit PM me I can give you a killa deal
Old Aug 19, 2009 | 03:49 PM
Foresite's Avatar
Foresite
No it's not lowered. It is a completely standard S.
Old Aug 19, 2009 | 04:06 PM
Triple_X's Avatar
Triple_X
a simple alignment should be able to take care of that
Old Aug 19, 2009 | 08:18 PM
ucla bruin's Avatar
ucla bruin
Your alignment might be out of whack from the factory/dealer then.
__________________
Old Aug 19, 2009 | 08:49 PM
G37Sam's Avatar
G37Sam
A strong dip/hole or even hitting against the curb hard could throw your wheel alignment off. Get us an alignment sheet if you can
indyn
Nov 17, 2015 06:48 PM
faze2988
Oct 7, 2015 12:05 AM
Irishcurtis
Sep 30, 2015 11:39 AM
John B
Sep 27, 2015 11:41 PM
ZachThomas
Sep 3, 2015 01:40 PM
