Help Technical question about wheel studs and lugs
Old Jun 20, 2009 | 07:05 PM
Does anyone know for certain the length of contact (in mm) of contact a wheel stud needs to have with the threads inside the lug in order to be secure and safe?
Old Jun 20, 2009 | 07:14 PM
Kidcane's Avatar
Kidcane
Florida G Club
I though the rule was 6 full turns of more.
Old Jun 20, 2009 | 09:04 PM
TJHG37S's Avatar
TJHG37S
I ran into this problem on my iForged wheels, they sat AT LEAST 5 but probably want 6-7 to be safe. Mackin makes special ET lugs that go into the wheel holes and allow for an extra couple of turns you may need. Amplified Motorsport can get em for you!
Old Jun 21, 2009 | 12:23 AM
WhiteG37S's Avatar
WhiteG37S
I work in a wheel and tire shop....6 full turns and you are safe.
Old Jun 21, 2009 | 12:27 AM
Mike's Avatar
Mike
5 full turns at the minimum, but more is better. I'm pretty sure you know, but don't overtorque to compensate for less turns, as this won't help it hold....
Old Jun 21, 2009 | 01:42 AM
So a consensus is 6 or 7 full revolutions. What does that translate to in mm of thread?
Old Jun 21, 2009 | 01:23 PM
Ivoidwarranties's Avatar
Ivoidwarranties
Are all studs the same pitch? How can you have a common rule using "turns" if so many different thread combinations are out there?
Old Jun 21, 2009 | 09:33 PM
Mike's Avatar
Mike
That depends on the thread size. On a G, I believe it is about 3/8-1/2 inch.
Old Jun 22, 2009 | 08:52 AM
Thank you sir! That's what I wanted to know.
Old Jun 22, 2009 | 08:58 AM
NJlakeshoreG's Avatar
NJlakeshoreG
def agree BB, MINIMUM like bare minimum is 5 turns, but i wouldnt be able to drive with a eased mind, and def 6-7 is perfect...i also believe its around a half inch...
ModInJapan
Brakes/Suspension
179
Jan 20, 2017 07:05 PM
ModInJapan
Wheel & Tires
98
Aug 7, 2016 06:04 PM
xstarpro
Jan 19, 2016 07:15 PM
news1213
Dec 16, 2015 11:06 AM
james6980
Oct 9, 2015 01:28 PM
