Official Low Offset/Hellaflush Thread
Ok guys im STILL tweaking the suspension. Prob going to leave it at this height, since its perfectly tucking tire all around. Also have to take into consideration all the crappy roads around here. Here are the specs:
F 19x9.5 +18
R 19x 10.5 +13
Dropped on Stance Gr+OEM. Tires are 235/35 & 255/35 Toyo T1R's. Running -2 camber up front and -5 camber in the back.
So looks great but can't drive it. The rear had credit card clearance from tire to fender and on the slightest imperfection it would rub. So we ended up taking the 10mm spacer off of the rear.
Now what would you guys recommend i should do? I dont want to pull my fenders. Fenders come pre rolled from factory.
1. Run spacer anyways and f up my fenders
2. Run smaller spacer (5mm) and hopefully it works.
3. Call it quits and run normal setup like everyone else. LOL
I apologize for the crappy pics.
F 19x9.5 +18
R 19x 10.5 +13
i say run a smaller spacers on the rear or none at all and bring your camber back to spec a bit that way it will stick out more then raise it back up a lil if you're still rubbing.
I dont know how u did it Wei. Been back and forth tweaking the suspension all month now. So close but yet so far away. Anyway, hope the smaller spacers will work out for you TomieG. Props to those out there trying the aggressive offsets with the 37. I wouldn't even do this unless I have bags.
from that shot it looks like it should still be able to camber in on bumps and be fine.
Im prob going to pull my fenders or run smaller spacer.
25 pages and only a handful of pics and offsets. For the guys that posted pics, all your cars look great.
I would like to see more please. This is what I was hoping for:StanceWorks
eg (not a g37, but still, you get the point)
so what's the correct size spacer ?
or what would be correct based on combo of tire size & spacers.
I wanted 245/35/20 for the front on 8.5 inch fronts.
& 275/30/20 for the rears 10.0 inch rears.
don't wanna mount evrything and have a problem.
