Spacers?
Old Apr 22, 2009 | 03:56 PM
jsingh's Avatar
jsingh
Spacers?
Ok so I've searced through the forum and come to the conclusion its going to be either 15 or 20mm all around with the stock wheels and tires.
What I need to know is the difference b/t the bolt on spacers and those that replace the existing wheel studs not bolting to them? I plan on being dropped on Eibachs with stock wheels and tires and switching to 245/275 after my stocks wear out. So which ones are better to go for and alleviate rubbing? Thanks guys.
Old Apr 22, 2009 | 09:32 PM
w0ady's Avatar
w0ady
15mm. sam rubs on 20mm with eibachs and wider tires.
im in the same boat. heard both are fine. our wheels allow the use of bolt-ons so those are easier to install.
Old Apr 22, 2009 | 09:55 PM
jsingh's Avatar
jsingh
So i'm going to go 15mm Fronts an 20mm Rears.
Old Apr 22, 2009 | 09:58 PM
G37Sam's Avatar
G37Sam
By searching through the forum you mean sent me 15 PMs? haha just pulling your leg bro
Bolt-on spacers are the way to go, stud replacement is a headache. You WILL rub with 275s in the rear & 20mm spacers. Part of my fendor lining went loose this morning so I just ripped it off. Haven't had the time to completely remove it yet
Old Apr 22, 2009 | 10:19 PM
jsingh's Avatar
jsingh
HAHAHA I think I PM'd you and AndrewDDS both about the same, lol
S*it sorry to hear that Sam, def not cool. What your plan of action?
But you didnt have any rubbing when you had the stock tires an 20mm did you?
Old Apr 22, 2009 | 10:23 PM
G37Sam's Avatar
G37Sam
Haha yeah you're so paranoid about it lol just get it done and whatever comes up can definitely be fixed.
I'm getting the lining removed tomorrow. The rubbing has eaten up part of the tire wall. And yes, no rubbing with 245s
Old Apr 22, 2009 | 10:25 PM
AndrewDDS's Avatar
AndrewDDS
You basically have to ask yourself, "Would I rather have 245/275, or would I rather have 20mm spacers?" If you'd rather have wider tires, then go with 15mm spacers. If you don't mind the stock tires, then go with 20mm spacers. Unless you want to be like Sam and rub some off every time you hit a bump... Wait, that came out wrong.....
Old Apr 23, 2009 | 09:07 PM
w0ady's Avatar
w0ady
think i might be getting 15mm bolt-ons all the way around.
Old Apr 23, 2009 | 09:20 PM
G37Sam's Avatar
G37Sam
^ just pull the dam trigger already man u been wanting to get them for like a month now haha
Old Apr 23, 2009 | 10:10 PM
TimsG37s's Avatar
TimsG37s
What are the best bolt on spacers for our car?
Old Apr 23, 2009 | 11:41 PM
AndrewDDS's Avatar
AndrewDDS
That's the setup I'm running and I love them. I went with Ichiba's because they seemed like the highest quality for bolt-ons.
Old Apr 23, 2009 | 11:42 PM
Kidcane's Avatar
Kidcane
Florida G Club
Nobody fans of the stud replacements huh? Thats the only way I will go.
Old Apr 23, 2009 | 11:48 PM
AndrewDDS's Avatar
AndrewDDS
I would prefer stud replacement, but I'm mechanically retarded and don't want to pay someone else to do it. Bolt-ons are within my expertise level, so that's how I roll. Good reason? Absolutely not. Am I cool with it? Most of the time.
Old Apr 24, 2009 | 11:06 AM
frcefed's Avatar
frcefed
I'd like to get spacers for my fronts. Is it true that you will get vibrations with spacers? That's my only worry about getting them.
Old Apr 24, 2009 | 11:18 AM
Kidcane's Avatar
Kidcane
Florida G Club
^^Not if they are hubcentric and installed properly.
