Arrrgh!
Old Apr 11, 2009 | 01:55 PM
Rodzilla's Avatar
Rodzilla
So if I needed 3 of my rims repaired, who would I call?
Old Apr 11, 2009 | 09:30 PM
johnnyg's Avatar
johnnyg
A+ DETAILING!!!!!!!!!!!!!!!!!!!!!!! If you have a G in Northern VA and do what I did ( curbed the wheel) Mustafa from A+ Detailing will get you straight!
Great job.......good as new. The only way to tell is that the previously damaged area has a Thinner clear coat than factory so it feels slightly less smooth than the factory finish. 90 bucks OTD. Support local business guys! The shop is in Fairfax and is a full detail service and wheel repair. He is contracted by Chantilly infiniti and several other high end dealers. I realy can't tell visaully where the repair was made. Paint matches perfectly. He put the G up on the lift prepped and airbrushed 3 coats then 2 of clear, heat drying between and he was done in a little over an hour. I just washed the car and it's back to dealer perfect. If you got to use a wheel repair shop this s the one!
