Can someone please check your stock wheels...
and let me know how it mounts up to the 'rotor' ?
i swapped out my winter tires with my stock summers, the rear (both left and right) sits flush when i installed it, however the front tires / rims seem to have a 1 mm gap. is this normal or something is wrong ?
here's a illustration.
it might be possible the hub rings are still on there, but hub rings wouldnt go into the stock wheels, so there would be a bigger space than 1mm.
was the hub rusty at all, and this gap was still there after you tightened the lugs down??
yes the hub was rusty, i cleaned it and sprayed it with wd40, and then torqued all the nuts to spec.
I also noticed that when I put my spacers on. I don't think there's actually a space there; look closer and I think you'll see that there is a tiny cuff on the wheel. I threaded a tiny dental mirror inbetween the spokes on my wheels to get a closer look and it looked they actually were sitting flush but the tiny bevel makes it look like there's a space.
Let me know if I'm wrong!
thanks everyone !
I'd mine installed and torque to spec 8 days ago, already traveled over 500km since.
Hmm, I just swapped in my summers and noticed pretty huge gaps in the front wheels (1mm is a conservative estimate), AND my car has been wandering left and right... I wonder if improperly installed rims is the problem.
KZK
Canada
Aug 20, 2015 09:36 PM
