Help Work Emotion Fitment
Old Feb 11, 2009 | 04:25 PM
RB-What?'s Avatar
RB-What?
Smile Work Emotion Fitment
Hey guys i really want to run Work Emotion CR KAI on my G37S 6mt.
So my next question is offset!! I want to run supper aggressive!!! I plan on buying the camber kit, toe kit and coil overs. So what sizes should i run??
(R)18x9.5 offset? Available offsets "38mm,30mm,20mm,12mm"
(F)18x8.5 offset? Available offsets "43mm,37mm,30mm"
Thanks!!
Old Feb 11, 2009 | 05:28 PM
w0ady's Avatar
w0ady
30/30 might be what you want, not 100%. why not contact 1 of the reputable work vendors on here? they should be able to help you the best.
Old Feb 11, 2009 | 05:36 PM
GiGGaplease's Avatar
GiGGaplease
30/30 will work if youre going to do negative camber. just make sure you kinda stretch your tires. i had 275/35 in the rear, this was with 10.5 +30 and i rubbed when going over bumps and stuff.
Old Feb 11, 2009 | 05:37 PM
RB-What?'s Avatar
RB-What?
Ok thanks guys!!
Old Feb 11, 2009 | 05:41 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
Are you sure these will clear the brakes? I thought the safe route was to have a little more than 4" of clearance between the brake rotor and the wheel (in this case 14" rotors and 18" wheels)
And will the offsets be enough to clear the calipers being a 8.5" wide wheel in the front and a 9.5" in the back?
Just wanna make sure all his bases are covered before he wastes his money on some wheels that might not fit....
Old Feb 11, 2009 | 06:06 PM
w0ady's Avatar
w0ady
^thats why you talk to a works vendor who knows what they're talking about.
j50ny
Jul 21, 2017 10:46 AM
helloandchau
Oct 6, 2015 05:26 PM
ay37
Sep 15, 2015 08:51 AM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
mmnjtwa
Sep 7, 2015 02:27 PM
